Audio Builds Audio projects and builds from my350z members
VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
Old Jan 11, 2008 | 01:10 PM
  #81
DustinZ33's Avatar
DustinZ33
cool. I just searched for fi q series. I found the website. It's ficaraudio.com
  #82
DustinZ33's Avatar
DustinZ33
Is that where you ordered from?
Old Jan 11, 2008 | 01:13 PM
  #83
VO...'s Avatar
VO...
Administrator
Sorry bro. Yes that's where I purchased it from. Turn around time is pretty quick too...
Old Jan 11, 2008 | 01:26 PM
  #84
DustinZ33's Avatar
DustinZ33
Man. That site is too detail for me. I don't know which speaker to choose. All I know is I want a single 10".
Old Jan 11, 2008 | 01:30 PM
  #85
VO...'s Avatar
VO...
Administrator
go to "speakers", they have 4 lines of subs. Click on either "BL" "BTL", "Q", or "SSD". They specs will be listed...
Old Jan 12, 2008 | 10:13 AM
  #86
DustinZ33's Avatar
DustinZ33
Yeah. I got that. I just don't understand the technical side. Don't know which sub would be best for me.
Old Jan 12, 2008 | 10:20 AM
  #87
doug's Avatar
doug
i think the BL and BTL are for SPL and the Q is for SQ
Old Jan 14, 2008 | 06:27 AM
  #88
VO...'s Avatar
VO...
Administrator
+1
Old Jan 14, 2008 | 08:11 AM
  #89
350zspl's Avatar
350zspl
VO. Where did you get your fi sub? I would like to check into this sub. Do they make 10"?
yes they make 10"
Old Jan 14, 2008 | 08:13 AM
  #90
350zspl's Avatar
350zspl
i can help you
what amp are you using
what final load do you want
what music you listen to
what is your budget
sealed or or ported
Old Jan 14, 2008 | 08:24 AM
  #91
VO...'s Avatar
VO...
Administrator
Default Update...
Well, I was busy this entire weekend so didn't have a chance to complete the install. I did make small progress though. I test fit the new 2inch mounting bolts I purchased recently, through the sub's mounting holes. The bolts did not work. The outer rim of the sub has a rubber ring that is about 1/4 inch thick. Theoretically, the head of the bolts is suppose to sink into the rubber out of sight. In my case, the bolts I purchased have a large phillups head on them. It was too large to sink into the rubber ring. The old allen head bolts I had are only 1 1/2 inch, which is too short.
I made a trip to Lowe's harware and found 2 inch allen head bolts. They fit perfect. Hopefully tonight I can complete the install.
I snapped a few pics of the FI Q vs. my old Rockford T1. I used a can of Neverdull for size reference......
Attached Thumbnails VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3406.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3407.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3408.jpg
Old Jan 14, 2008 | 08:27 AM
  #92
350zspl's Avatar
350zspl
OC and i were speaking of the length you need
2" will be close
2.25 or 2.5 " will be perfect
the black rubber piece is called a gasket
  #93
350zspl's Avatar
350zspl
the RF looks very made in China the 12 spoke FI Looks so custom made by Scott in Nevada
i love 12 spoke
Old Jan 14, 2008 | 08:40 AM
  #94
VO...'s Avatar
VO...
Administrator
I could not locate anything above 2". It's ok though, the T-nuts I have are 1/4 inch long. The added length of the T-nut will increase the length of the bolt, so to speak.
Old Jan 14, 2008 | 09:46 AM
  #95
StreetOC192's Avatar
StreetOC192
Yeah, you should be good with the 2"
Old Jan 15, 2008 | 06:46 AM
  #96
DustinZ33's Avatar
DustinZ33
i can help you
what is your budget
sealed or or ported
I most likely will be using a JL 500/1
final load???
a variety. some rock, some hip-hop, some electro
200-300, maybe more for a nice sub
sealed
I don't want something for extreme bass. I would like something that sounds good. I do want a sufficient amount of bass but not overboard.
Old Jan 15, 2008 | 06:48 AM
  #97
VO...'s Avatar
VO...
Administrator
final load???
sealed
I still haven't completed my FI install, but I'd say that FI subs are on the extreme side. Definitely not your everyday common sub IMO. In my case, the kind of bass I'm looking for is the kind that moves your shirts and impairs your vision..
Old Jan 15, 2008 | 06:54 AM
  #98
350zspl's Avatar
350zspl
final load???
sealed
Fi Q
FI SSD
RD Classic
RE se or sx
all would work sealed off your 500 watts and be in your budget
Old Jan 15, 2008 | 07:04 AM
  #99
VO...'s Avatar
VO...
Administrator
Fi Q
FI SSD
RD Classic
RE se or sx
Wouldn't running 500watts rms into a FI Q series severly underpower it? I believe it was said that "underpowering a sub causes more damage than over powering it".
Old Jan 15, 2008 | 07:07 AM
  #100
DustinZ33's Avatar
DustinZ33
Fi Q
FI SSD
RD Classic
RE se or sx
Thanks.
I don't think they make a 10" FI Q though.
Who makes these two? RD Classic and RE se or sx......nevermind. I found em.
