Audio Builds Audio projects and builds from my350z members
2x 15" dc subs =)
Old May 4, 2013 | 04:08 PM
DBTre50z's Avatar
DBTre50z
Those door pods look great! Going a little conservative with that amp though no?
Old May 4, 2013 | 09:20 PM
Qtip350z's Avatar
Qtip350z
Nice work so far! I would love to hear it when your done. I'm in vancouver as well.
Old May 5, 2013 | 09:26 AM
wrecker's Avatar
wrecker
u bet.. if it ever gets done.. pods took for ever to make
Old May 5, 2013 | 05:49 PM
quakerroatmeal's Avatar
quakerroatmeal
Crazy build! You're moving pretty fast. What are your goals? Just to get loud/low. Did you ever get the old setup on the TL to see how loud it got? You going for aeroports again? I love me a loud system..running 1 dc3.5?
Old May 18, 2013 | 11:49 PM
wrecker's Avatar
wrecker
finally an update..
building box today
tuned 32 hz
Attached Thumbnails 2x 15" dc subs =)-air-velocity.jpg   2x 15" dc subs =)-box-side.jpg   2x 15" dc subs =)-iso.jpg   2x 15" dc subs =)-tfm.jpg   2x 15" dc subs =)-explode.jpg
Old May 19, 2013 | 02:00 AM
wrecker's Avatar
wrecker
loud and low..
never did test the old setup.. but it did bounce the wipers on the windshield.
just 1x 3.5k atm..
Old May 19, 2013 | 01:48 PM
wrecker's Avatar
wrecker
almost there
Old May 20, 2013 | 08:16 AM
wrecker's Avatar
wrecker
perfect fit..
loud enough ??
i even have room on the sides of the box for a pair of 8"s and 6.5"s
Attached Thumbnails 2x 15" dc subs =)-pict3903.jpg   2x 15" dc subs =)-pict3907.jpg   2x 15" dc subs =)-pict3909.jpg   2x 15" dc subs =)-pict3904.jpg   2x 15" dc subs =)-pict3905.jpg
Old May 20, 2013 | 04:24 PM
wrecker's Avatar
wrecker
Attached Thumbnails 2x 15" dc subs =)-pict3911.jpg   2x 15" dc subs =)-pict3912.jpg   2x 15" dc subs =)-pict3913.jpg   2x 15" dc subs =)-pict3915.jpg
Old May 21, 2013 | 04:42 PM
350Z_Al's Avatar
350Z_Al
That's a huge box for a Z!! If they're pretty heavy duty subs you're using I'd recommend adding another layer of 3/4" to the baffle as well as bracing the inside of the box if it's not too late.
Old May 22, 2013 | 11:38 AM
wrecker's Avatar
wrecker
way ahead of ya.. fiber glassing the inside and 2nd layer still coming
i will be doing some steel bracing on the outside as well in the mounting process
Old May 22, 2013 | 08:08 PM
wrecker's Avatar
wrecker
so far i have painted the port. the box will be wrapped in black vinyl
all screws have been counter sunk / body filled . sanded and glassed .
just have to put 2 full layers on the back and time to start mounting
box will be bolted to the side pillars and rear brace
Attached Thumbnails 2x 15" dc subs =)-pict3917.jpg   2x 15" dc subs =)-pict3918.jpg   2x 15" dc subs =)-pict3919.jpg   2x 15" dc subs =)-pict3920.jpg
Old May 24, 2013 | 10:07 PM
wrecker's Avatar
wrecker
did my side mounts.. using stock pods
2x 8" spikes each side
box goes in tomorrow
Attached Thumbnails 2x 15" dc subs =)-pict3921.jpg   2x 15" dc subs =)-pict3922.jpg
Old May 25, 2013 | 04:08 PM
wrecker's Avatar
wrecker
box wrap
install
Attached Thumbnails 2x 15" dc subs =)-pict3932.jpg   2x 15" dc subs =)-pict3931.jpg   2x 15" dc subs =)-pict3934.jpg   2x 15" dc subs =)-pict3935.jpg
Old May 27, 2013 | 06:48 PM
wrecker's Avatar
wrecker
subs mounted and all wire ran back to the trunk
just need to build a beauty panel around the subs
and design an amp rack
Attached Thumbnails 2x 15" dc subs =)-pict3942.jpg   2x 15" dc subs =)-pict3944.jpg   2x 15" dc subs =)-pict3945.jpg   2x 15" dc subs =)-pict3947.jpg   2x 15" dc subs =)-pict3948.jpg
Old May 27, 2013 | 07:14 PM
quakerroatmeal
How much space are you giving per sub before displacement? Doesn't seem like much. How much port area do you have as well? Should have just walled off the entire back . I hope you break 150 on music.
Old May 27, 2013 | 07:35 PM
wrecker's Avatar
wrecker
3.25 Cubic Ft Each 6.00 Total
Tuned to 32 Hz
Port is 2 x 20.5 x 27.75 (Note that because the port is on the angled face the end is also angled, also they combine for a 4 inch port within the middle of the box)
Port air velocity below 30 m/s.
TFM Graph included with roll off point. posted down below
might be close to 150 db.. i will try it out.. see how she does.
i could easily get another 3.5 k hit that magic 150db..
its all fun
Old May 28, 2013 | 09:19 PM
  #38
wrecker's Avatar
wrecker
rough hooked her up ..
holy **** its a ****in beast
Old May 30, 2013 | 11:48 AM
  #39
wrecker's Avatar
wrecker
bass **** .. this thing has brutal bright lights on it ..
i recommend installing it in a place where u can cover it up
Old May 31, 2013 | 10:43 PM
  #40
quakerroatmeal
Post up some more pictures and flexing videos.
