DIY Rear View Camera Install
Old Jun 15, 2009 | 09:44 AM
  #41
dkmesa350z's Avatar
dkmesa350z
Originally Posted by Maddawg
Try a BOYO-VTL-200 or 300 RVC CCD. Black or Chrome Zinc Alloy Frame. Well worth the price. Very high resolution night vision. Visionhiteac.com
He posted that over two years ago lol. But thanks for the heads up.
Old Dec 2, 2009 | 07:41 PM
  #42
*ICE*'s Avatar
*ICE*
can anyone tell me exactly where to find the wire to tap to from the headunit? I am unable to find the green wire from the first post's pics.
Old Dec 3, 2009 | 04:59 AM
  #43
dkmesa350z's Avatar
dkmesa350z
The green wire in the trunk for the reverse signal? Mine was there but I recall having to do a little hunting. Maybe the newer ones are different. If so, I would imagine you could find the wire for one of the reverse lights and splice it.
Old Dec 3, 2009 | 05:26 AM
  #44
*ICE*'s Avatar
*ICE*
yea, where is that green wire in the trunk for the reverse signal? Did you have to remove all carpet and plastic parts in the hatch area?
Old Dec 3, 2009 | 02:09 PM
  #45
dkmesa350z's Avatar
dkmesa350z
If you remove the carpet then take the vertical piece of plastic at the back of the trunk out, the wire is about 6 inches down and 4 inches to the right (if you are facing the front of the Z) of the trunk latch IIRC.
Old Mar 9, 2010 | 08:45 PM
  #46
J. Dub's Avatar
J. Dub
thank you for this write up
Old Mar 21, 2010 | 04:06 AM
  #47
Kiriller's Avatar
Kiriller
Where can i find the reaverse light wire so i can tap into it? is that the light green wire that you have in the picture? thanks in advance,
& thanks for info installing today
Old Mar 21, 2010 | 06:54 AM
  #48
dkmesa350z's Avatar
dkmesa350z
there ya go
Old Jul 12, 2010 | 01:09 AM
  #49
*ICE*'s Avatar
*ICE*
Originally Posted by Jhon Herry
they are pointless it's just for peoples who are lazy to turn their head around in the cars. i don't think it's that expensive to get it professionally fit into your car i think it should be around 200 for the device and installation.
_____________________________________________
its not lazy because you have to parallel park a lot in the East Coast. Having the camera make it easy knowing when it is too close to the car behind you or get to that tight parking spot you wouldn't able to make w/o the camera
Old Jul 12, 2010 | 01:44 AM
  #50
dmroberson's Avatar
dmroberson
+1. I've had my camera on for almost 3 years now... Helps me a lot...
Old Jul 28, 2010 | 09:42 PM
  #51
ucsmfu's Avatar
ucsmfu
is it possible to get the reverse camera to work on stock 2007 350z nav ?
Old Aug 9, 2010 | 03:18 PM
  #52
lockedcogs's Avatar
lockedcogs
I was also wondering the exact same thing!
Old Aug 9, 2010 | 03:34 PM
  #53
dkmesa350z's Avatar
dkmesa350z
not sure if this will work on 07s, but this allows a video input:
http://kptechnologies.com/products.php#/6
Just a weird note on my rearview camera- my old cam stopped working after 1.5 years. I replaced it with the identical camera, but it stopped working the same day. Turns out something shorted the s video cable. I replaced it with a third camera and made sure to use plenty of electrical tape and wire loom.
Old Sep 16, 2010 | 10:25 PM
  #54
Linuxglobal's Avatar
Linuxglobal
to play the rear view cam on a stock nav would require the same kit to view movies on the stock navi. The screen isnt made for video resolution on the oem nav so its not the greatest idea but it will work with most aftermarket modules. You would most likely have to switch views manually from nav to rear view unless the kit includes an automatic feed.
As for your shorting out issue, it sounds a bit strange, even a thin layer of electrical tape will protect the circuit for up to 600volts. Perhaps the wire got snagged somewhere along the body metal? My friends g35 lost the power trunk when the stock wire was cut in the trunk area and this was oem wiring.
Im waiting on my camera but I already ran the cables through the car and out to the license plate. Its a good idea to make the cable as solid as possible around sharp body metal openings. I used that grey round styrofoam stuff made for copper pipes (its like 1$ for a 3 foot piece). its not pretty but noone sees it anyways.
Good luck with the install
Old Sep 22, 2010 | 11:01 PM
  #55
Sena's Avatar
Sena
very clean... very impressive
Old Dec 29, 2010 | 11:08 AM
  #56
gvulakh's Avatar
gvulakh
[QUOTE=Linuxglobal;8663322]to play the rear view cam on a stock nav would require the same kit to view movies on the stock navi. The screen isnt made for video resolution on the oem nav so its not the greatest idea but it will work with most aftermarket modules. You would most likely have to switch views manually from nav to rear view unless the kit includes an automatic feed.
Can you or anybody else recommend a specific module that will work to have a back up cam work on a stock 04 Z's nav screen?
Old Dec 29, 2010 | 11:37 AM
  #57
DavesZ#3's Avatar
DavesZ#3
Does the stock navi even have a video-in connection?
Old Dec 29, 2010 | 11:43 AM
  #58
gvulakh's Avatar
gvulakh
It does not. I found a module on ebay that lets you hook up a bu cam and dvd player...it goes for $179 shipped.
Found a pricier one with a google search that goes for $350.
Another member/friend asked me if I could install a bu cam in his 04 Z to work with his factory nav screen so I went researching...........
Old Aug 12, 2011 | 03:22 PM
  #59
bmccann101's Avatar
bmccann101
post mortem thread bump.
found this today.. its a replacement back up light housing w an integrated BU camera.
I personally opted for the ALpine unit sold to go along w my head unit, and am installing it in my Veilside rear end so it is unseen...
but this was super cool and very cheap.
and heres the ebay sales link:
http://cgi.ebay.com/ebaymotors/Car-R...item3a6826bce5
Old Aug 12, 2011 | 06:05 PM
  #60
Jackson0927's Avatar
Jackson0927
Wow thats neat. Price is almost too good to be true. Worried quality would render it useless. May have to be the guinea pig. Not much to loose @ $25
I just don't wanna pay $200 for the matching (pioneer) camera.
