Dash Lights & Digital Gauge Pod Quit After Theft
Old Mar 20, 2020 | 04:33 AM
mweaver987's Avatar
mweaver987
Cool Dash Lights & Digital Gauge Pod Quit After Theft
2003 350Z coupe manual, someone broke the driver window and stole the aftermarket radio and sub amp. I was driving without it and all of a sudden the dash lights quit completely and so did the digital info pod. Anything I need to do before I install my new aftermarket radio and amp?
Old Mar 20, 2020 | 04:43 AM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Check the connections on the white control box behind the A/C heater controls, this box also controls the gauge clusters.
Old Mar 20, 2020 | 04:46 AM
mweaver987's Avatar
mweaver987
Do I have to remove the white box to see the connection? I see the ribbon from the hvac controls going in but cant tell much else...
Old Mar 20, 2020 | 04:55 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Yes- the white control box is easily removed and you should check both the connector and the ribbon wire itself. Also check the fuses for the instrument and gauge panel.
Old Mar 20, 2020 | 05:46 AM
mweaver987's Avatar
mweaver987
Where is the dash light fuses located, the descriptions I have found for the boxes are extremely vague.
Old Mar 20, 2020 | 07:06 AM
mweaver987's Avatar
mweaver987
Also, before this happened my tail lights stayed on alllll the time..... (tail lights not brake lights)
Old Mar 20, 2020 | 07:15 AM
jhc's Avatar
jhc
General & Tech Moderator
It would be helpful if ALL the problems were stated concisely in the beginning. Anything else to add?
Old Mar 20, 2020 | 07:19 AM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Sounds more and more like a damaged control module. I have a different issue where both my turn signals come on anytime I turn on parking lights. I just ordered a replacement module from ebay for $30, cheap way to troubleshoot further.
Old Mar 20, 2020 | 08:50 AM
mweaver987's Avatar
mweaver987
Radio was stolen, tail lights would stay on alllll the time until I unhooked the battery, was driving home one day and the dash light quit along with the digital info readout in the pod but at the same time the taillights started working normally. Going to hook up the new radio this evening.
z33ryans
Sep 2, 2019 01:31 PM
VoodooJC
Dec 19, 2008 08:57 AM
tractng
Dec 17, 2004 06:30 PM
Dre Dizzle
Feb 13, 2004 05:32 PM
stevelee2001
May 22, 2003 08:12 AM
