Need help, battery won’t hold charge
Old Jan 23, 2021 | 12:02 AM
350ZzenN's Avatar
350ZzenN
Default Need help, battery won’t hold charge
I’ve just got a 2003 Z this week, put crazy hours into it to get it inspection ready.
-new battery diy
​​​​​​-new alternator diy
-new clutch slave/bleed diy
-new tires diy
-front bumper lights installed diy
-oil change as well as new gasket on oil pan, new oil sensor(leaking fixed)
anyways, I’m wondering how many connections the alternator should have. the guy who has the car before me replaced the engine, and the alternator was not routed correctly; instead it was routed straight back to the starter, skipping the alternator all together. I had both the battery and alternator tested at autozone and both had hard fails.
When i replaced the alternator, i didn’t realize the cable wasn’t there,i thought it was weird, but the battery cable was not “there”, this is my first Z. So all i plugged in was the boot connector, and tightened it all back together. Noticed it wasn’t holding charge, so i thought, there’s gotta be a battery cable, found it re-routed it and connected it, and it still won’t charge.
is it possible that i burnt out the alternator? Or are there more connections to it than the plastic boot connecter, and battery?
If it’s a fuse, with one? And where? Thanks guys!
Old Jan 23, 2021 | 01:41 PM
350ZzenN's Avatar
350ZzenN
Default Update
I pulled the positive battery cable out, and tested both the alternator connection and they started connection, and they are both great, don’t know what the problem is here, unless the alternator is bad.
If i was looking for a fuse where would it be on 2003?
i have checked the fusible link also
Old Jan 23, 2021 | 07:55 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you checked the fuse box in the DS footwell?
Old Jan 23, 2021 | 08:09 PM
350ZzenN's Avatar
350ZzenN
Default Solved
Yes, checked all fuses, turns out autozone sold me a bad alternator. Got it replaced under warranty.
Just checked it with the multimeter. It was putting out 11.69V
boostintt
Sep 29, 2013 04:33 PM
Blazemaster
May 14, 2010 12:46 PM
R@lph'$ 350z
Jan 30, 2010 12:32 PM
BreadTalk
Oct 12, 2007 07:12 PM
Dui-Dan
Sep 17, 2007 10:09 AM
