Who needs Koni's for the Track???
Old Feb 21, 2005 | 02:06 PM
cwalker's Avatar
cwalker
Default Who needs Koni's for the Track???
Are the Yellow Koni's necessary for the Track Model? Was looking at them on TireRack and they don't list them for the Track - they do for all the other models.
I've read that the Track has different suspension settings than the other models.
Old Feb 21, 2005 | 03:18 PM
arizzee's Avatar
arizzee
suspension is the same for every trim level in a particular model year. IOW, the Track's suspension is the same as the Base's suspension. Now the wheels, brakes, diff, vdc and such, that's a different story.
Old Mar 14, 2005 | 05:02 PM
dkmura's Avatar
dkmura
General & DIY Moderator
I have the Koni 8241 Sport shocks on my track model and recommend them highly. The rebound revision to the OEM settings makes a significant difference to how the power gets put down at the track. As the above post correctly states, there was no difference in the suspension settings for the track model vs. any of the other models (much to my disappointment).
Old Mar 15, 2005 | 04:50 PM
gpslater's Avatar
gpslater
dkmura, what settings do you use on your Koni's?
Old Mar 15, 2005 | 06:17 PM
Jason H's Avatar
Jason H
I might have some slightly used Koni yellows for sale if anyone is interested. Might be switching to double adjustables?? Still waiting to see if the rules allow the threaded bodies or not. PM me if you're interested.
Drive on!
Jason
Old Mar 15, 2005 | 09:53 PM
Gsedan35's Avatar
Gsedan35
Rebound revision? Gordon specifically mentioned that they valved them to have less compression dampning them oem. I don't see why the rebound dampnng can't be different, but they are adjustable for rebound anyhow.
Old Mar 15, 2005 | 09:54 PM
Gsedan35's Avatar
Gsedan35
Drive on!
Jason
Good chance I will be interested, but how long have you been running them with T2 springs?
Old Mar 16, 2005 | 06:16 AM
Jason H's Avatar
Jason H
I've only done 1 test at VIR with the T2 Springs and Konis (springs didn't come out 'til late last year) and I've done about 5 races on the konis with stock springs. Let's keep in touch if you might be interested. There's nothing wrong with them, I just might be changing to a threaded body double adjustable. We'll see.
Take care,
J
Old Mar 16, 2005 | 05:38 PM
Gsedan35's Avatar
Gsedan35
Take care,
J
Ah I see. Yeah if you had run those T2 springs very much, I'd be a little worried knowing their spring rates. Yes, let's keep in touch. Do you have a estimated time line when you'll know what your going to do for sure, truechoices?
apex locator
Jul 23, 2021 02:27 AM
