Do I Need P/S Cooler & Oil Pan Spacer?
Old Apr 8, 2005 | 04:16 AM
zman2's Avatar
zman2
Default Do I Need P/S Cooler & Oil Pan Spacer?
Getting ready to track my Z in hot Florida.
How important is a better power steering cooler?
What is the worst that can happen with the stock cooler?
Important to have either new oil pan or spacer?
Thanks
Old Apr 8, 2005 | 04:49 AM
GaryM05's Avatar
GaryM05
You shouldn't need either right away. I had over a dozen track days on my Z before I boiled the power steering fluid and decided to get the cooler.
I suppose the worst that can happen with the stock cooler is that your power steering could diminish/fail, but you'll see & hear signs of that coming long before it would actually fail. For me, I decided to upgrade after hearing a very loud thumping/banging/cavitating sound from the front of the engine bay during cornering (the sound would increase in speed and volume the more I cranked the wheel, and would go away as I unwound the wheel.) Once I installed the Nismo PS cooler, the problem was solved.
Unfortunately, I don't have much input on the oil pan spacer, as I'm still running all stock for that and haven't had any problems.
Gary
Old Apr 8, 2005 | 12:06 PM
speedform's Avatar
speedform
[QUOTE=GaryM05]You shouldn't need either right away. I had over a dozen track days on my Z before I boiled the power steering fluid and decided to get the cooler.
Agreed.....your steering will tighten up a bit as you loose/boild the PS fluid. Not a big deal right away. Just go have some fun. cheers,
Old Apr 8, 2005 | 02:21 PM
Eagle1's Avatar
Eagle1
I put in the higher capacity ARC oil pan (6.75 qt) and a high capacity Koyo radiator, and kept the stock thermostat. The car ran Big Willow in 106 degree air temps and while there were other cars that were either encountering heat problems or feathering back to keep running, the car just cruised around and the needle stayed in the sweet spot all the time. If you are going to be running in hot air, the combination is certainly worth considering.
Old Apr 8, 2005 | 10:29 PM
AznIceRckt's Avatar
AznIceRckt
Gary
excellent info, you just saved me some money for a while.
phil
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
