Hot Lap timing system
Old Jul 23, 2005 | 05:24 AM
mberthia's Avatar
mberthia
Default Hot Lap timing system
Has anyone installed a Hot Lap system in their car without having a roll cage or harness bar ? There seems to be enough dissagrement on whether a roll cage or harness bar is better for a street driven car with occasional track days that I have not purchased either of them.
Any good way of installing the received solidly in place ?
Thanks
Martin
Old Jul 23, 2005 | 08:26 AM
zillinois's Avatar
zillinois
Thanks
Martin
One of the guys that tracks with us, used to use zip ties and straps it to the headrest of the passenger seat. Then he leaned the seat back to point the ir beam out the back window. I'm not sure if it would work on the driver's side though.
Old Aug 1, 2005 | 10:47 AM
daveh's Avatar
daveh
I've saw a corvette driver with a great idea. He made a metal bracket shaped like a stair step then closed his trunk on it. It sat on the outside of the car and was easily tranferred to any car of his choice.
Let me know if this makes sense.
Old Aug 1, 2005 | 01:59 PM
dnguyent's Avatar
dnguyent
It didn't make sense at all. What I'm envisioning in my head right now would make anyone laugh their heads off.
Old Aug 1, 2005 | 02:01 PM
rednezz's Avatar
rednezz
Thanks
Martin
I zipped tied my sensor to the passenger side visor and tilted the visor down to a 45 degree angle. I then mounted the display where the NAV goes with velcro. It works great at the track and I am able to take it down when I go home.
Old Aug 1, 2005 | 02:05 PM
daveh's Avatar
daveh
Piece of metal that looks like this. Mount the transmitter on top of it and close your trunk on the bottom bend.
edit: had to insert the periods because the spaces were deleted. Pretend the periods are not there and you are left with a piece of metal that is bent like stairs.
......._____
___|
Old Aug 1, 2005 | 02:59 PM
dnguyent's Avatar
dnguyent
......._____
___|
I think I get it now...the lower left lip of the bracket is secured by shutting the hatch, thereby clamping it in place. The transmitter is actually mounted outside the car then... That is certainly unconventional!
Old Aug 2, 2005 | 05:10 AM
mberthia's Avatar
mberthia
Where do you point the sensor ? towards the passenger side or towards the driver side window ? The transmitter signal is ususally placed on the driver side of the track.
Thanks
Old Aug 2, 2005 | 05:31 AM
rednezz's Avatar
rednezz
Thanks
The events I attend usually put the transmitter on the passenger side so I point the sensor out the passenger window. I don't know if it would work pointing out the drivers window but I don't see why it wouldn't work as long as there isn't any obstruction.
Old Aug 2, 2005 | 05:33 PM
mberthia's Avatar
mberthia
That's the best option so far. I'll have to buy one next month and try it out. I'll ask the PCA guys to make sure that they will let it pass inspection. I assume inspection has never been a problem for you ?
Hanging out from the hatch is also good but I would need to be careful with a braket that would not move and scratch the paint. That will be plan B for now.
Thanks
Old Aug 3, 2005 | 05:25 AM
rednezz's Avatar
rednezz
Thanks
No I haven't had problems with the PCA inspections. Actually it was the instructors that told me to try mounting it like that. Just make sure you zip tie it down good. Also, what I did to test my sensor position is I hooked it up and put the display in setup or test mode (It displays a 0 when it receives an IR signal). I then got a TV remote control and I had my girlfriend aim the remote from approximately the same location and angle from where the transmitor would be. While I was in the car looking at the display I had her push the channel changer on the remote to see if the sensor was detecting a signal. You can try that to see if your sensor location will work for you.
Old Aug 3, 2005 | 12:21 PM
sfarrah's Avatar
sfarrah
Either way i'd suggest going with a cage or roll bar rather than a harness bar. If you roll over with a harness bar, you're basically screwed. If the roof collapses in on you you're toast as you're held upright in your seat. If you have a cage, it won't collapse. If you don't have a cage, and you don't have a harness, at least you can lean sideways or forward to prevent you from getting crushed. Just my $.02.
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
SharX59
Sep 30, 2015 10:54 AM
SharX59
Sep 27, 2015 09:23 AM
