Camber adjustment
Old Mar 13, 2006 | 01:27 PM
Autoxr's Avatar
Autoxr
Default Camber adjustment
How are you guys adjusting for neg camber in the front of the car. Is there an alternate bolt available from Nissan to adjust the upper control arm? In stock form it seems there's no available adjustment.
Old Mar 13, 2006 | 03:16 PM
dyezak's Avatar
dyezak
This is the one thing that keeps the Z from murdering the old M3's and RX8's in BS....no neg front camber.
Old Mar 13, 2006 | 03:33 PM
dkmura's Avatar
dkmura
General & DIY Moderator
That's correct- there is only a limited amount of front camber adjustment designed into the Z33. There are a wide variety of adjustable upper A-arms available on the aftermarket, however.
Old Mar 13, 2006 | 03:35 PM
PDX_Racer's Avatar
PDX_Racer
M3 "murdering" is already occurring.
Most RX-8s don't know it yet, but they are going to be "toast" very soon now...
Old Mar 14, 2006 | 07:21 AM
Autoxr's Avatar
Autoxr
Adjustable A-arms aren't allow in a stock class though (I'm pretty sure).. That's what raised my question, as I'm trying to fit 275-40/17s on my car as I've read most drivers are using and the tire sticks out past the body. Just wondering how all the guys running in BS are running 275s up front no problems.
Old Mar 14, 2006 | 09:21 AM
mpowers's Avatar
mpowers
7.5 inch wide front wheels thats how.
Old Mar 14, 2006 | 11:49 AM
Autoxr's Avatar
Autoxr
ah, I see... Damned Canadian models were outfitted with 8.5" all round.
Autoxr's Avatar
Autoxr
dbl post sorry
Old Mar 14, 2006 | 12:20 PM
mpowers's Avatar
mpowers
Thats a good problem to have!
Old Mar 14, 2006 | 01:19 PM
Autoxr's Avatar
Autoxr
Just means I can run 275 on the rear and only 255 on the front (or at least I'm thinking 255 should fit in the wells). Oh well, like you say, it's not the worst problem to have.
Old Mar 14, 2006 | 02:42 PM
dyezak's Avatar
dyezak
You could have a rotory.................................
Old Mar 14, 2006 | 07:42 PM
christoc's Avatar
christoc
You could run a spacer, not sure how much room you'll need inside though. For SCCA competition the spacer can't be more than 1/4" +/- the stock offset.
Old Mar 15, 2006 | 06:23 AM
Autoxr's Avatar
Autoxr
Spacer are going to push the wheels out even further though? Not sure how that's going to bring the tire in.
I'm running a 24mm offset at the moment with a 17x9 wheel (in Canada we're allowed to change wheel size due to our prep point rules), the wheel is in side the well, but the tire bulges outside allowing tread to be seen extending outside the wheel well. Being new to 350s I hadn't discovered the lack of camber adjustment on the front untill now. =P
Old Mar 15, 2006 | 06:24 AM
tomsn16's Avatar
tomsn16
PDX RACER....why do you think the RX8's will soon be toast? Hope you are correct but wonder why.
Old Mar 15, 2006 | 07:23 AM
christoc's Avatar
christoc
Visions of sugar plumbs
Old Mar 15, 2006 | 07:24 AM
christoc's Avatar
christoc
I didnt realize you were trying to keep the tires inside the fender, I though you were worried about clearance issues on the inside.
Old Mar 15, 2006 | 08:34 AM
Autoxr's Avatar
Autoxr
Yeah, the 275s clear, just, without spacers.
Old Mar 15, 2006 | 10:39 AM
PDX_Racer's Avatar
PDX_Racer
Only .131 off off Joe's time in SD -- without the cones on my fastest runs -- and with the brand new Hoosiers "giving up" on me (and Stephen)...
(and did I mention that there were at least three big sweepers in the courses -- something that the RX-8 excels at?)
I left at least 0.1 on the course on Saturday, and 0.2 on Sunday (big screwups right where I should have been getting on the gas).
Old Mar 15, 2006 | 11:11 AM
tomsn16's Avatar
tomsn16
Hey Glenn....that is a good report.I had not analyzed the cone effects at SD.
We had same problems with S05's last year....lets hope the A6 is a real tire.
JIm & Carter
Old Mar 15, 2006 | 11:33 AM
PDX_Racer's Avatar
PDX_Racer
I kind of wished I still had decent S04s -- they were significantly better at not overheating, but I still ran the shoulders off of them.
I also need to get my car down to Fordahl's and get a real alignment! Joe and Jason were giving me a hard time about that...
