Track prep... help
Old Jul 4, 2006 | 03:16 PM
GaryM05's Avatar
GaryM05
Originally Posted by MoodDude
Instead of creating a new thread - thought this would apply here.
I was preping my car (again) today. As usually I was checking all the suspension linkages for fatigue and that the bolt are all tight. I found two bolts that where coming loose (lucky for me) and tightened them.
So just make sure you check your suspension over carefully before any track event.
Just thought I share with you guys.
Glad you found that during the prep, and not the hard way at the track. What bolts were they?
Old Jul 4, 2006 | 03:23 PM
MoodDude's Avatar
MoodDude
One bolt was on the front sway bar the other was holding the linkage that supports the rear spring (that would be scary if I lost that one).
Old Jul 4, 2006 | 03:29 PM
Stack's Avatar
Stack
Blue LocTite is your FRIEND!!
Old Jul 4, 2006 | 05:35 PM
MoodDude's Avatar
MoodDude
Yes, it is!
apex locator
Jul 23, 2021 02:27 AM
