Racing wheel studs
I just found these and ordered them:
Advent Performance
http://www.adventperformancellc.com/...4542_4532.html
Products
1 x Mackin Industries SR48 Open End Racing Lug Nuts M12x1.50 (32906/B/N/T) = $59.99
Color Black
Sub-Total: $59.99
United Parcel Service (1 x 14lbs) (Ground): $9.65
Total: $69.64
And I got the ARP studs from SPL:
4 100-143L ARP wheel stud 14.3mm knurl long set of 5 49.50 198.00
1 20033SD Gorilla SD lug nut set 12mm x 1.5 open end 29.00 29.00
But these lug nuts are splined and use a special tool....I don'r like that for track-useT
Advent Performance
Products
Color Black
Sub-Total: $59.99
Total: $69.64
This is my first purchase from Advent, so hopefully things will go well...so far = good. Mario from Avent sent me an intro email after my online order..nize touch....here is his email info.
mrnegron@adventperformance.com
BTW: As you may know, the auto world is shut down while everybody is at SEMA this week....
My stuff is alleged to ship next week!
I don't remember how many track days I've done or how many times I had the wheels off/on but it is a bunch. I started with the OEs, then I migtrated to the Nismo 60mms. I noticed some strectching on the Nismos, similar to the stock ones. I picked up some ARP studs for a suburu at summitracing, they are 3" long and about $10 each. The fronts installed very easy but the rear were a PITA, I ended up having to take the ebrak cable out and installing them trrough that hole. They are long and long winded when you are runing a M12 x 1.25 on them, but I have had zero strectching in the two years ro so I've used them.
I run 275/35 and 295/35 Kumho MX or 275/40 hoosiers, with all of that lateral pull I've had no drama with these.
Will closed end extended legnth lug nuts fit over those longer ARP studs or do they have to be open ended? Are they 60mm as well?
Looks like ARP 100-7716, which is ~1.2 inches longer than stock
http://www.arp-bolts.com/catalog/Cat...atalog066.html
Other possible issue is the knurl length is about 1.14mm "too short" but may actually be fine.
I actually use wheels spacers to, I have several sets of wheels that I use on and off of the track, and spacers just make fitment that much easier. I torque the Porject Kicks to 70 lb/ft and I have never had one com eloose, stretch or leave me wanting in any fashion.
I really contemplated going the 1/2 route, and really can't remember why I didn't.
I actually use the porject Kics R40 lugnuts, they are closer to 75 mm (3") though I have never really measured what atualy extends through past the hub. Lets just say there is plenty of thread there to meet you.
Just take a hammer and knock out the studs in your spacers and then install the longer studs. I really discourage the usage of spacer/adapters with studs pressed in them, except for show cars, generally those apadters are not thick enough to take the lateral load that a good sticky tire can exert.
100-7717
100-7718
will all fit, but you need to determine what will work for your needs
Getting rid of the studs built into your space my be an option; how thick are the spacers?
Why are you guys using a 1.5 thread pitch stud?
The Subaru STi wheel studs work great, and are M12x1.25. They are 3" long so if you're not using a 10-20mm spacer you may want to machine them shorter.
Part #: ARP 100-7716
I ordered M12x1.25 open ended lug nuts from stockington wheel and tire I think they were called. I ordered like 200 lug nuts hahaha. I can't find their website now so maybe I have the name wrong. Sorry guys!
Post update:
My lugs from Advent showed up as promised..good service from them..
Lugs look fine...
Lugs look fine...
I think I'm going with the ARP Subaru studs (12 x 1.25) since the specs are the same as the Z. I just want to minimize the hassle of having to change out my lug nuts.
I will take some pics this weekend
unless you are using 20mm spacers, you'll need new open ended lug nuts anyhow..
