CAN bus readers
Old May 14, 2006 | 07:03 PM
Rob Hines's Avatar
Rob Hines
Default CAN bus readers
Does anyone have a CAN bus reader in the DC area? I tripped an ABS code and need to read and reset it.
On the same topic, does anyone have a recommendation for an inexpensive CAN / OBDII reader for the Nissan. If money were no object, I'd go with the consult, but I'm looking for somethink quite a bit cheaper.
Thanks!
-Rob
Old May 14, 2006 | 08:08 PM
350Zteve's Avatar
350Zteve
There's no such thing as a cheap CAN reader yet. The one I'm buying tomorrow is located here www.autoenginuity.com.
Old May 14, 2006 | 08:14 PM
christoc's Avatar
christoc
Since I know nothing about these, what do they allow you to do? Just scan for codes?
Is it possible to adjust wheelspeed sensors to account for different sized tires on the street? Rather than having to turn off the TCS every time I start the car?
Old May 14, 2006 | 08:44 PM
350Zteve's Avatar
350Zteve
This one does more that most, but you would have to call them for specifics.
Old May 19, 2006 | 09:58 PM
cruddydude's Avatar
cruddydude
Thanks!
-Rob
Is this for a 350Z application? As far as I'm aware, the Z uses ISO-9141 for the OBD-II physical layer, and not CAN. The Z's OBD-II connector does have a CAN bus, but it doesn't seem to be used for OBD-II.
aarrgghh
May 1, 2022 11:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
soupnazi1
Mar 7, 2004 09:53 PM
DaveO
Dec 5, 2003 07:50 PM
