2006 Base Corner Weights/Alignment
Old Jul 25, 2006 | 01:51 PM
betamotorsports's Avatar
betamotorsports
Default 2006 Base Corner Weights/Alignment
FWIW:
2006 base model 350Z
CORNER WEIGHTS
7-12-2006 - 35 psi tire pressures, 40 lbs of fuel, no spare, no jack, no tools, no modifications.
Without Driver
Total: 3,217 lbs.
Front: 1,792 lbs. - 55.7%
Rear: 1,425 lbs. - 44.3%
Left: 1,583 lbs. - 49.2%
Right: 1,634 lbs.- 50.8%
Cross (RF/LR): 1,598 lbs. - 49.7%
LF: 889 lbs. RF: 903 lbs.
LR: 694 lbs. RR: 730 lbs.
With Driver
Total: 3,432 lbs.
Front: 1,890 lbs. - 55.1%
Rear: 1,542 lbs. - 44.9%
Left: 1,741 lbs. - 50.7%
Right: 1,691 lbs.- 49.3%
Cross (RF/LR): 1,697 lbs. - 49.5%
LF: 966 lbs. RF: 924 lbs.
LR: 775 lbs. RR: 767 lbs.
ALIGNMENT
These are the factory settings as delivered.
Front
Camber LF: 1.0-
Camber RF: 1.0-
Caster LF: 9+ SAI: 6.0
Caster RF: 9.2+ SAI: 6.2
Total Toe: 1/32" in
Rear
Camber LR: 1.1-
Camber RR: 1.1-
Total Toe: 1/16" in
Old Jul 26, 2006 | 12:18 PM
daveh's Avatar
daveh
Thanks for posting. I found the same near perfect cross weights both times my car was on the scales.
Old Jul 26, 2006 | 02:14 PM
TrackHoRX8's Avatar
TrackHoRX8
Is the alignment with the driver in the car or just the car itself?
Old Jul 26, 2006 | 03:15 PM
betamotorsports
No driver for the alignment numbers.
Old Jul 26, 2006 | 03:25 PM
teh215's Avatar
teh215
Great post! Thanks!
Old Jul 27, 2006 | 05:13 PM
hippie's Avatar
hippie
Since there is some debate about the weight of early v/s late Zs, I'll post the weights of my '03 Track.
No driver, 3/16 tank of fuel (30 lbs?), no tools or spare. The only options are the side air bags.
TOTAL....3118
LF...849
RF...886
LR...697
RR...687
Let the games begin.
Old Jul 28, 2006 | 04:15 AM
jun14scr's Avatar
jun14scr
That's your base weight, right Mike?
Old Jul 28, 2006 | 04:21 AM
hippie's Avatar
hippie
Yes. That's before shocks, bar, or the Ti exhaust. The shocks are a couple lbs heavier, the bar is about the same, and the exhaust is...well...54lbs lighter than stock.(assuming the stock is really 65 lbs) I think the car is around 3060 right now.
Old Jul 28, 2006 | 06:36 AM
christoc's Avatar
christoc
My 03 Enthusiast in last year's prep weighed in at 3075.
We now run a full tank of gas instead of completely empty, we've changed the front bar, and now have a TI ypipe with a 3" exhaust system back. I'd guess in our '06 configuration we'll weight in around 3200. Mainly due to the difference in running 1 gallon of gas and 20 gallons.
Old Jul 28, 2006 | 07:11 AM
jun14scr's Avatar
jun14scr
What benefits do you see from running a full tank versus on the light?
Old Jul 28, 2006 | 07:18 AM
christoc's Avatar
christoc
More weight over the rear wheels, leading to less inside tire spin, though it's not fully solved, it does help the fact that our diffs suck.
Old Jul 28, 2006 | 07:54 AM
jun14scr's Avatar
jun14scr
Hmm I see. Do you run with the spare tire inside then also?
Old Jul 28, 2006 | 10:03 AM
christoc's Avatar
christoc
Depends on how lazy I am that day.
Old Jul 31, 2006 | 05:37 AM
Axelerate's Avatar
Axelerate
I put my car on the scales yesterday while at a HPDE and it weighed 3420 lbs. with me in it, and a full tank of gas. Spare tire and everything else was removed.
I was also pleasantly surprised that it's already corner weighted.
Old Jul 31, 2006 | 10:22 AM
Fluid1's Avatar
Fluid1
Why would you use a liquid (gasoline) as opposed to leaving the spare tire (solid) in the back??? Fuel slosh would deter me from running with full tank, if I wanted weight I would go with the spare..... possibly because the fuel is lower in regards to the center of gravity by a little?
Old Jul 31, 2006 | 03:24 PM
ULLLOSE's Avatar
ULLLOSE
If the tank is full slosh should not be an issue. In the Corvette we did the same thing, pulled the spare and ran a full tank.
Old Jul 31, 2006 | 06:58 PM
christoc's Avatar
christoc
What he said. We've also got the car setup loose enough we can get the back and to dance a bit if need be.
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
