Track spares package
Old Jul 27, 2006 | 08:55 AM
uwaeve's Avatar
uwaeve
Default Track spares package
So if you were fortunate enough to go away for 8 track days in one fell swoop, what would you bring for spares? I have the following list, what am I forgetting?
Pads
Rotors
Oil & filter
Brake fluid
Various crush washers (brake lines, diff, tranny)
Gear oil
Union bolts for brakes
Brake bulbs
Money for tires
Thanks in advance.
uwaeve
Old Jul 27, 2006 | 10:13 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
Coolant and/or distilled water and power steering fluid. Just in case you boil one or both, it is summer afterall. I would also bring some spare hose in various sizes for coolant lines, radiator hose, vaccum, fuel, etc.
Old Jul 27, 2006 | 10:24 AM
betamotorsports's Avatar
betamotorsports
Having done all three iterations of OTC (http://www.opentrackchallenge.com) you'll need everything on your list plus:
Engine Oil and filter
Coolant
Fan belt
Radiator hoses
Electrical wire, connectors, and shrink wrap
Rear halfshaft
Rubber hose in various IDs
**** clamps
Bailing wire
Exhaust mounts and clamps
Valve stems
Extra lug nuts and wheel studs
Wiper blades
Extra car battery
Anti-roll bar bushings and end links
Tie rod ends
Steering rack boots
CV joint boots and grease
and lots more...
Old Jul 27, 2006 | 10:26 AM
SinCity350Z
Track Whore
^^^I don't know about all of that, but I do agree with adding the belts and lugs / studs to the list.
Old Jul 27, 2006 | 11:01 AM
uwaeve's Avatar
uwaeve
Thanks for the great replies.
If I don't want to spend all the money on a **** clamp, can she just use the seatbelt in a pinch?
I'm not one to point out typos, but that one read great.
Old Jul 27, 2006 | 11:03 AM
SinCity350Z
Track Whore
Depending on the track, you may need a clamp.
Old Jul 28, 2006 | 06:17 PM
Triple8Sol's Avatar
Triple8Sol
If you have sways setup aggressively, endlinks might not be a bad idea?
Old Jul 31, 2006 | 07:36 AM
betamotorsports
Forgot to add "Condom" after the "**** Clamp." Always think Safety when working with ***** and clamps.
Old Jul 31, 2006 | 12:35 PM
Fluid1's Avatar
Fluid1
awesome
Old Jul 31, 2006 | 02:59 PM
MoodDude's Avatar
MoodDude
Differental Gear Oil wouldn't be a bad idea either.
