17x9.5 wheels all around?
Old Dec 25, 2006 | 01:00 PM
  #61
12AutoX's Avatar
12AutoX
It's already low enough to make speed bumps and driveways a hassle, so when I do get some springs/shocks, I will look for something close to OEM ride height. The hard part is done- I pressed in longer wheel studs yesterday to accomodate the spacers. I also bought some open ended lug nuts. I can easily swap out spacers at will now.
Tha hard part is waiting for Jan 7 to try out the new tires!
Old Dec 25, 2006 | 04:25 PM
  #62
Sk8fe's Avatar
Sk8fe
Jan 7! I gotta wait until April! Man, I gotta move my sorry-six south!
Old Apr 13, 2007 | 07:33 AM
  #63
commasense's Avatar
commasense
Sorry to revive a 4-month old zombie thread, but I've been wondering about something.
I just put on the SSR Comp-H's (17 x 9.5) with 5mm Eibach spacers, and I'm wondering if I have enough stud length with the stock studs. Nobody here mentioned replacing them with longer ones, so am I okay on track with the stock studs?
daveh or anyone else running this setup?
Thanks.
Old Apr 13, 2007 | 07:40 AM
  #64
03Z33's Avatar
03Z33
Should be fine. I believe the minimum number of turns required is 6 or 7 full turns on the lug nut.
Old Apr 13, 2007 | 08:03 AM
  #65
Sk8fe's Avatar
Sk8fe
Agreed.
commasense, nice avatar! Way to keep that LeMans Sunset in front of that "P-car" at the top of the esses at The Glen!
Old Apr 13, 2007 | 08:04 AM
  #66
daveh's Avatar
daveh
Thanks.
I run the longer studs that came with my 5mm spacers. If you don't have them, I know nismo and ARP make 10mm longer studs. I've never counted the number of turns I get, but it just seemed like good insurance to run the longer ones. Come to think of it, I might replace mine soon just for regular mantenance.
Old Apr 13, 2007 | 08:13 AM
  #67
amolaver's Avatar
amolaver
i've got the 17x9.5" comp-h's as well - i broke down and bought the ARP studs. the oem's were a PITA because they were short and the wheels had deep recesses anyway, so getting your fingers in there to start the nuts stunk.
ahm
Old Apr 13, 2007 | 09:44 AM
  #68
Sk8fe's Avatar
Sk8fe
What are the part numbers for the ARP longer studs? I called them and the guy on the phone didn't know and just sent me a catalog.
Old Apr 13, 2007 | 03:59 PM
  #69
commasense's Avatar
commasense
What's involved in removing the stock studs? Aren't they pressed into place?
Old Apr 14, 2007 | 10:13 AM
  #70
03Z33's Avatar
03Z33
Yes but a tap with a hammer will push them right out. You'll need to unbolt the brake caliper, slide off the rotor and then you have access to the hub where the studs are pressed in. When installing the new studs, I use a standard nut with a spacer (in place of the wheel and lug nut) to press it in.
Old Apr 15, 2007 | 06:53 PM
  #71
amolaver's Avatar
amolaver
ARP part number 100-7718
Package says they're for '86-'89 Celica GTS. Keep in mind these use a 12x1.5 thread pitch nut. I'm using open ended nuts from advanced autosports available here:
http://www.advanced-autosports.com/p...studs_nuts.htm
I use these on my SM as well which makes it nice since I only carry one type of spare.
ahm
Old Apr 16, 2007 | 01:33 AM
  #72
Sk8fe's Avatar
Sk8fe
^^^ Thanks!
Old Apr 16, 2007 | 05:46 AM
  #73
commasense's Avatar
commasense
And just tighten it in with a big wrench?
Old Apr 16, 2007 | 05:51 AM
  #74
03Z33's Avatar
03Z33
It doesn't need that much torque to seat the stud. Probably less than 80ft/lb. You could always use a BFH from the back too
Old Apr 16, 2007 | 06:55 AM
  #75
amolaver's Avatar
amolaver
if you buy the lug nuts from advanced autosport, ask them to include the thick washers they send with their stud kits for the miata. after you pop out the old ones (BFH is the way to go - one moderate strike with a 5 lb sledge pops 'em right out), you push the new ones in and put these two super thick washers on the studs. throw a new nut on the stud, and impact 'em down. my HF cordless impact had enough juice to seat 'em. basically, you just need enough of a spacer so the socket doesn't bottom out before the stud is pulled tight.
highly recommended that after you install them and torque your wheels, go for a spirited 50 mile drive or one practice-pace session, pull the wheels, then retighten the studs.
ahm
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
