Rotor Vibration
Old Jun 11, 2007 | 05:29 AM
nicolaycastro's Avatar
nicolaycastro
Originally Posted by RKnight
I had pad deposits on my front Stop Techs after a track event you could not detect by looking at the rotors but it made the whole car shake when braking. The fix was Stop Tech send me a set of Hawk Blues that I made several repeated stops just like bedding in a set of new pads. Cleared it right up.Then I sent the pads back to Stop Tech and they charge $50.00 for the rental.
I think that is deffenetly it, I bought some new front rotors and the vibration went away. But I will keep the old ones as replacement and will defenetly use stronger pads to remove the pad deposit when needed. Thanks for the info.
Ohh and I know better than to use the parking brake after runs.
Old Jun 11, 2007 | 07:54 AM
betamotorsports's Avatar
betamotorsports
Braking style on a race track has a lot to do with how pad material is deposited on the rotors. Two types of braking styles are especially prone to uneven pads deposits:
1. Hard brake application that gets into the ABS.
2. Medium brake application that gets into the brake slowly and then pops off the pedal.
And in 16 years of racing I've never had a problem with e-brake application (on those race cars I've driven that had e-brake) after an autocross or track run and none of the folks I've raced with have ever mentioned a problem. If you drive the cool down lap as you should (cooling the car down), e-brake applicaiton shouldn't ever be a problem.
Old Jun 11, 2007 | 08:39 AM
tmak26b's Avatar
tmak26b
it doesnt matter. the ebrake on the Z is a shoe setup, not a disc setup like most cars.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
