Anyone use Wheel Spacers at the Track?
Old Jul 28, 2007 | 11:42 AM
joeygill's Avatar
joeygill
Default Anyone use Wheel Spacers at the Track?
Here's why I'm asking:-
I did a test-fit of some project kics spacers today. There is a set of lug nuts that bolt the spacer to the hub. A second set of lug nuts (your usual wheel lug nuts) bolts the wheel to the spacer. At the track, I always make it a habit to re-torque my lugs between sessions. However, with spacers, it looks like it is necessary to have to re-torque BOTH sets of lug nuts. This would be a pain, when at the track.
What do you folks you run spacers at the track do? Or are there other alternatives to this?
Old Jul 28, 2007 | 02:19 PM
betamotorsports's Avatar
betamotorsports
I run spacers that slip over the wheel studs not the adpater kind.
Old Jul 28, 2007 | 02:52 PM
joeygill's Avatar
joeygill
Who makes the ones you use? Are these like the H&R Trak ones, where we have to get a separate set of longer studs?
Old Jul 28, 2007 | 03:52 PM
merlot350Z's Avatar
merlot350Z
Several people make spacers, we bought our from TC Kline in Hilliard, Ohio. They are the bolt on type and come with new slightly longer, but also stronger wheel studs. We torque them at 80#'s. It really doesnt matter what wheel spacers you put on, its just that the bolt on type don't fall off and get lost. Once they are on you don't need to torque them again. The H & R spacers are also excellent quality.
Old Jul 28, 2007 | 05:05 PM
John's Avatar
John
Ichiba spacers are hub-centric, good quality, come with longer studs, and cost less than the H&Rs. Plus you can source extra longer studs from them as well...
Old Jul 28, 2007 | 06:32 PM
DmanG281's Avatar
DmanG281
I use Nismo long studs and spacers I picked up from either Summit or Jegs I can't remember but they both sell them. They are super cheap at 20 bucks a set. Good quality as well.
Old Jul 28, 2007 | 06:57 PM
joeygill's Avatar
joeygill
So I guess, consensus is that I should do away with the Project Kics style spacer, and go with ones where the studs hold both the spacer and wheel together thus only needing a single set of lug nuts per wheel...right?
(still trying to get my head on straight on this )
Old Jul 28, 2007 | 07:59 PM
z-u-later's Avatar
z-u-later
Not necessarily. I have both setups in my Z. My fronts are H&R 20mm spacers (longer studs with removable spacers). For the rear, I have H&R 25mm spacers (spacers are bolted to OEM studs), which are similar to the Project Kics. As long as they are installed correctly, it should not matter which setup you use for the street/track. I've driven my Z both on the track & autocross without issues.
Old Jul 29, 2007 | 02:28 PM
WA2GOOD's Avatar
WA2GOOD
+1, me too
