HELP! Anyone had a pinion bearing fail???
Old Oct 8, 2007 | 11:45 AM
Axelerate's Avatar
Axelerate
Default HELP! Anyone had a pinion bearing fail???
Here's the story:
https://my350z.com/forum/engine-and-drivetrain/306538-help-rear-end-issues-pinion-bearing.html
Wanted to see if anyone else who tracks thier car has had something silmilar happen.
I'm instrtucting this weekend and I have to get it fixed ASAP!
thanks!
Old Oct 8, 2007 | 01:24 PM
joeygill's Avatar
joeygill
Sucks to hear that, Brett. Best of luck, and I hope everything works out before the weekend!
Old Oct 8, 2007 | 03:19 PM
Axelerate's Avatar
Axelerate
I dropped it off at another dealer that agreed to do the work. Noise wasnt as bad as before, and I dont hear any gear noises, just sounds like a bearing.
Another thing it does is the rear end wanders very badly over bumps, feels like it's going to spin!
At least I caught now instead of on the way to the track.
Old Oct 8, 2007 | 03:27 PM
betamotorsports's Avatar
betamotorsports
I've lost a couple pinion bearings on race cars. One failed because of a too long halfshaft on the driver's side that put a big side load on the ring gear and pinion shaft. The other failed from heat. Plumbing a diff cooler and making sure the return line from the cooler emptied onto the pinion shaft solved that problem.
Old Oct 8, 2007 | 05:26 PM
Axelerate's Avatar
Axelerate
Did the gears get fried when the bearing failed?
Old Oct 9, 2007 | 07:22 AM
betamotorsports
In the first example the gears got fried because of the side load. In the second example the gears were blue'd but were fine. I did send the gears out and get them REM treated which helps reduce heat generation.
Old Oct 9, 2007 | 07:34 AM
Axelerate's Avatar
Axelerate
I just got the call that the entire rear end needs to be rebuilt with the exception of the LSD.
I'm trying to find some 3.9 gears now so I least get something out this. It is going to be EXPENSIVE!!!
Old Oct 9, 2007 | 08:35 AM
Axelerate's Avatar
Axelerate
UPDATE!
I found the Central 20 3.9 gears from www.everything350z.com, they seemed to be the only ones I could find in stock. They are being overnighted to my dealer and they should have it back together tomorrow!
I should be good with a new rear-end and better gearing, defeinelty the most I've spent on my car at once! I knew I was due to drop some money on it eventually, it's been good to me.
So, for those who might have this issue I had a pinion bearing fail which knocks everything out of alignment and chewed up the gears. The dealer is replacing everything except the housing and my Cusco LSD. If I had a stock diff it would of been under warranty, but I am paying for it all and upgrading my gearing. I should be good for this weekend!
It's amazing how fast they work for non-warranty work!
Old Oct 9, 2007 | 11:06 AM
betamotorsports
The most magical two words in the service department of any dealership: Customer Pay.
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
samansharif
Sep 25, 2015 12:31 PM
