What;s a realistic "track weight"
Old Oct 15, 2007 | 07:53 PM
97supratt's Avatar
97supratt
I weighed my car two weeks ago with 5 gallons of gas and it tipped the scales at 3180 lbs without driver. I'm hoping to get that number around the 3000 lb mark in the next year.
Old Oct 15, 2007 | 09:18 PM
UnderPressure's Avatar
UnderPressure
Originally Posted by John
I believe that 2650 weight is for the GT cars in the Rolex series, not the GS cars in the Grand Am Cup. I believe those were 2900-3000 IIRC...
Your right about the GT series
Straight from the GT rulebook:
2-17 Nissan 350 Z (Prep 1 and 2)
2-17.1 3.5 Liter VQ35DE ,13:1 compression,RRZ31-Spec 2 heads, 515/264 In,485/250 Ex. Camshaft ,38 lb crank piton /rod 902 gms.
2-17.2 Tire sizes are 280/640R18 front and 295/660R18 rear
2-17.3 minimum weight prep 1: 2,600
So that would mean the Playboy #35 & #33 have to be at least in the ballpark.
And for GS:
Nissan 350Z
(3.5) 2003 -
2006
3.53:1 19.0 2900
287 HP Track option model allowed. Tire size: 245/40/17 front, 275/40/17 rear. NISMO
Aero package #G2010-RNZ30 allowed. Exhaust headers allowed. Allowed fabricated
front upper control arm with sliding ball joint mount for camber adjustment. Allowed 7 1/2
inch lightweight clutch/flywheel assembly. Allowed Nismo cam kit part #99996-RSKK.
Aftermarket front caliper upgrade as per rules. May use aftermarket ECU.
Old Oct 16, 2007 | 04:52 AM
bigdaddy's Avatar
bigdaddy
WHAT THE HELL IS THIS?!?!?!?!?
You know you would have eventually broken the Z too.
Old Oct 16, 2007 | 05:06 AM
mhoward1's Avatar
mhoward1
HAHAHAHAHAHAHAAA....
and will you follow with a return to a Z?
Old Oct 16, 2007 | 05:28 AM
mhoward1's Avatar
mhoward1
BTW Eric,
The 350Z's did very well in T2. So they are really getting sorted out.
Old Oct 17, 2007 | 06:08 PM
Eric1h's Avatar
Eric1h
Originally Posted by mhoward1
BTW Eric,
good to know, thanks marty,
ANyone want to trade for a well sorted full race BME e36 M3 :-D
Old Oct 18, 2007 | 01:35 PM
dmoffitt's Avatar
dmoffitt
I'm tempted... I had WAAAAAY too much fun in the Z at the Glen earlier this week but then again my instructor's M3 was incredible...
Old Oct 20, 2007 | 06:47 AM
Fluid1's Avatar
Fluid1
A gentlemen in my area did a costly but effective project of stripping weight.....from hardware, nuts and bolts... Not only did he replace numerous bolts of all sizes with titanium hardware, but also drilled out the center of the Ti bolts to lose more weight. IIRC, his Z is under 3k lbs. Those of course are not his only lightweight reduction.
Old Oct 20, 2007 | 06:50 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by 350zippy
Eric,
my car is at 3080 lb as you described, except i have kirk roll bar( not cage).
pm sent with information if you want to know details.
John knows me and the car before underwent significant changes.
cheers,
jose
Yup, we performed the strip search of Jose's car. I was very surprised with how light the car is. Still havent removed anything under the dashboard, but everything else in the car is gone.
I am probably going to do the same thing to my car. It's a lot less expensive to take 300lbs of the car, vs. adding power. It's amazing how well Jose's car handles in the ultra-light configuration.
Old Oct 20, 2007 | 09:16 AM
John's Avatar
John
If I still had my Z, I would actually trade you... oh well. LOL
Old Oct 25, 2007 | 05:14 PM
Lightning Guy's Avatar
Lightning Guy
I was at rockingham last weekend and got to drive a friends 350z and forgot how much I enjoyed driving the Z on track!
Glad you liked it. It was nice actually hearing it go 'round from the outside. I'll make it a point to weigh it this weekend and get you some numbers of where mines tips in. I feel confident you could still easily shed 200 to 300 pounds off of my car, with the expensive CF/lexan bits and loosing the AC and heater core.
AS far as I know I'm the only nimrod that has gone that far. I assume you are talking about the flat 'dime' head bolts I found, cut off, and then drilled the centers out. I'm not under 3k yet, but I'm working on it. I did shed ~34 pounds by swapping hardware.
Old Oct 25, 2007 | 05:24 PM
SinCity350Z's Avatar
SinCity350Z
Track Whore
Our time attack car is stipped, with full cage and it weighs 3,068 w/o driver. We also have the added weight of a TT kit, extra fluids (oil & coolant), and we still have the door panels, all factory glass, dashboard, center console shell, and power steering. We did cut out all of the sheetmetal from the rear strut tower brace and the area where the glove boxes and rear speakers were though and integrated those areas into the cage. Before we did that, we had a Kirk roll bar and all of that sheet metal still in there and it weighed 3,240.
apex locator
Jul 23, 2021 02:27 AM
