mid-ohio crash
Old Sep 10, 2013 | 01:28 PM
  #141
thekinn's Avatar
thekinn
In my case, the issue presented itself before I removed the dust shield. Then after I hit my first gravel trap, I replaced the hubs (and the dust shield came off too) and did not do any shimming.
Once I get the car back I will see if I can get a close look at this. Needed a little frame work.
Old Sep 10, 2013 | 03:03 PM
  #142
Neimad's Avatar
Neimad
Here's the whole ABS service manual, many things are specified for ABS function that might be being overlooked; pedal stroke, axle play etc.
http://pdf.textfiles.com/manuals/AUT...e/2003/brc.pdf
It would really help to have the $1300 Nissan Consult 3 to follow correctly though.
Old Dec 4, 2013 | 12:32 PM
  #143
sanbaifo's Avatar
sanbaifo
To those with failures and VDC, was your yaw sensor disabled at the time?
Old Dec 4, 2013 | 12:45 PM
  #144
laze1's Avatar
laze1
Yes, Mine was disconnected...and I had the dreaded "Hard Pedal" and not stopping issues...at 135 MPH
Old Dec 22, 2013 | 12:48 PM
  #145
SE5spd's Avatar
SE5spd
Bumping this - I had what I believe was ice mode (hard pedal, not really stopping) luckily buttonwillow has plenty of run off.
07 base model
Base model calipers
ST45/43 pads
9.5/10.5 wheels on 275/285/35/18 RS3
Stock camber
Old Dec 22, 2013 | 01:54 PM
  #146
03threefiftyz's Avatar
03threefiftyz
Were you trail braking? Stock camber + hard on the brakes while turning = meh.
Old Dec 22, 2013 | 09:30 PM
  #147
SE5spd's Avatar
SE5spd
Here's the video.
http://www.youtube.com/watch?v=rNB48...ature=youtu.be
Old May 30, 2014 | 09:14 PM
  #148
Z33KLF's Avatar
Z33KLF
Ouch, this is too bad!
Upstreammiami
Sep 17, 2015 02:45 AM
peptidbond
Oct 24, 2003 07:58 PM
DavidD
Oct 21, 2003 09:49 PM
DougT-Z
Jun 15, 2003 11:58 PM
jfive
Feb 22, 2003 05:09 PM
