BBK vs upgrading the Brembos
Old Jun 15, 2009 | 04:32 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Well I bleed after each track event with Motul 600. I don't want to spend $100 on fluid. I am going to try pads again and see what happens.
Old Jun 15, 2009 | 04:41 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
with the money you spend bleeding after each even, and buying new pads, it might be worth it to just try a better fluid in the first place - overall, less expensive, and you'll be getting stuff that is better than what you're currently using, and lasts substantially longer. No need to bleed your fluid after every event on a street car. Heck even on our ITS cars, which are race only, we change fluid only 1 x per season.
Old Jun 15, 2009 | 04:45 AM
Moroccan_Mole's Avatar
Moroccan_Mole
the cost may seem expensive, but it's definitely worth the investment. you don't need to flush the fluid after every event.
Old Jun 15, 2009 | 05:46 AM
josesantigo57's Avatar
josesantigo57
x2, no need to flush the system, but bleeding is absolutely necessary before each event. Besides very little fluid is lost from this.
Old Jun 15, 2009 | 05:47 AM
mhoward1's Avatar
mhoward1
While Fooshe and I don't always agree...I deffinately do on this post. With your current car and tire set up a good set of pads and decent fliuds should be fine. With the amount of heat you are seeing I would recomend having an instructor take a look at your overall braking times, brake pedal application, and maybe even free foot placement. These are little tweeks all of us need to keep working on no matter how experienced we are.
Fooshe really did a good job of summarizing it though.
Old Jun 15, 2009 | 06:33 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I am working with Carbotech for some pads right now. I wonder if he carries the fluid you guys mentioned. I will ask him.
Old Jun 15, 2009 | 07:24 AM
Moroccan_Mole
z1 has the endless fluid in stock.
Old Jun 15, 2009 | 08:05 AM
betamotorsports's Avatar
betamotorsports
Two pages of thread about brake fluid boiling and not one person has mentioned getting air to the front brakes (I apologize if I missed it)? Run some ducting! Much cheaper then anything else proposed here so far... :-)
Old Jun 15, 2009 | 08:49 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
That is the plan as well once I find some to use. But it is not a air issue as I have bled and bled the brakes.
Old Jun 15, 2009 | 08:58 AM
betamotorsports
Oh Geez!
Cooling air to the center of the brake rotors. Look here:
https://my350z.com/forum/members/bet...e-ducting.html
Old Jun 15, 2009 | 09:23 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I misread what you said. I thought you meant air in the lines. LOL!
That is exactly what I want to do there and my bumper is designed for it. I just need to figure out where to get the hose and what kind.
Old Jun 15, 2009 | 09:53 AM
Ataru074's Avatar
Ataru074
http://www.pegasusautoracing.com/pro...p?Product=3621
2.5" diameter will works, 2.5" aluminum pipes and weld an aluminum flange... betamotorsport did a great job.. probably less than 100$ in materials including the welding... I'm checking the clearance in the back of the brembos
Old Jun 16, 2009 | 04:04 AM
jmark's Avatar
jmark
The stock Brembos are used by the T2 350Z racers so I tend to believe they will work. They do have a brake ducting kit allowed. I think Rob uses Carbotech pads.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
