The Tire DB - Posts about Track and AutoX tire brands
Old Aug 15, 2008 | 06:06 PM
  #401
bdblackz's Avatar
bdblackz
Geez Rob, way to write a novel on this!! Glad to see you getting the hang of the Z.
Slow*Jim, what's up? Ross here. When are you letting missy drive your car? Just so i know to stay very far away from the course that day
Old Aug 15, 2008 | 06:49 PM
  #402
Slow*Jim's Avatar
Slow*Jim
Ross! Hey man! She thinks she is driving it tomorrow but I just tell her that so she doesn't dump me
You need to come out to a NASA HPDE some time!
Old Aug 16, 2008 | 09:42 AM
  #403
dmoffitt's Avatar
dmoffitt
I'd bet at least some of it is the fact that the 615 is easy to get to change from grippy to greasy vs the overall-lower-grip-but-harder RE040. Also check your tires pressures (likely too high?) - seems pretty normal reaction / behavior tho...
Old Aug 16, 2008 | 10:13 AM
  #404
mw9's Avatar
mw9
Originally Posted by Axelerate
Veilside version 1.
After looking at it closely the front rims BARELY fit! The front tires are close to the outer fender, but I'm only running -1.5 camber. I change it to -3 at the track.
You change you own camber. IF so what are you using?
Old Aug 16, 2008 | 01:53 PM
  #405
Axelerate's Avatar
Axelerate
Yes, front only with SPL race spec A arms.
Old Aug 17, 2008 | 06:58 PM
  #406
12AutoX's Avatar
12AutoX
Originally Posted by Eagle1
it just happens a bit sooner and is subtle, such that it "takes" precisely at the point on the track surface you want it to, which at higher speeds is quite a bit farther down the road than when you initiated the command with your hands and feet.
I remember discovering and learning to use the "delay" from input to execution on my first open track day. What an epiphany. This is an informative thread- I never tried to track the Z on a square setup, and now I'm not sure that I would want to.
Old Aug 18, 2008 | 01:12 AM
  #407
terrasmak's Avatar
It only takes one corner for them to get greasy, but they do cool down after about 2 or 3 corners. I run 37 hot front and 36 hot rear.
Old Aug 18, 2008 | 04:40 AM
  #408
mhoward1's Avatar
mhoward1
Remember that the OEM understeer setup is placed in there for safety and driver comfort. Most people are more comfortable with a car that pushed and scrubs off speed on it's won vs one that is loose and has a lot more rotation. It is a learning curve, and one that well all have to do if we change anything fundemental on the car we are use to driving.
But over all a loose car will be quicker once the driver is use to it and can properly rotate it. It will mean that you will have greater slip angles and at each corner exit you will be pointed in the right direction sooner allowing you to apply more throttle sooner.
Just have fun with it and slowly increase the spped back up. And have fun with it. I find a looser car to be more fun after a while. I good friend of mine once said
"I tight car scares the driver and please the passenger, a loose car pleases the driver and scares the passenger".
Old Aug 18, 2008 | 06:20 AM
  #409
whitt1's Avatar
whitt1
Bridgestone is already producing the RE-11R as a replacement for the RE-01R,they are supposed to be a big improvement when they are introduced in the US,they've been available in Japan for about a year.
Old Aug 18, 2008 | 09:04 AM
  #410
AznSky's Avatar
AznSky
I think I see what you mean Marty. I can see a very experienced driver throw a neutral car into a corner faster than one with understeer. But for me to get to that level will take years. Oh well, this is only my first season and I'm pretty young (23) so I should have a lot of time ahead of me.
As for everybody commenting on the 615's, maybe they're a better autox tire than road course tire? My next tires will probably be R-01R's
There's a lot of really good info in this thread regarding what some ppl are saying about turn in points changing and such that I'll have to read more deeply to understand it all.
And I think Ed's idea of playing on a skidpad is an excellent idea to get an understanding of the vehicle's new dynamics. I've been trying to use autox courses for that, but it's totally killing my road course smoothness. So where am I gonna find a skid pad.........
Old Aug 18, 2008 | 09:55 AM
  #411
mhoward1's Avatar
mhoward1
I wouldn't be so sure it will take you years. It's just a matter that you are driving an almost a brand new car, so it will take some getting use to, especially one that isn't tuned to OEM specifications.
As far as skid pads, a lot of track day groups and HPDE's are now offering optional skidpad time, so I would check with the organizations you tipically register with.
Old Aug 18, 2008 | 11:08 AM
  #412
dmoffitt's Avatar
dmoffitt
that's pretty much my take on them. I think the NT01 might be something to consider too if it's going to be on a set of "drive them to the track and back" wheels vs drive-everyday
Old Aug 18, 2008 | 11:41 AM
  #413
Eagle1's Avatar
Eagle1
I think that is a point.
Two observations. 1) don't ever drive them on public roads in the wet. That means wet, moist surface, not even considering rain! 2) don't drive them on public roads (or most other R compounds) in temperatures below 45 F.
Old Aug 21, 2008 | 12:05 PM
  #414
mario23's Avatar
mario23
Has anyone tried the Enkei Rpf1's 17X10 yet for a square setup?
I see they have a +15 and +38 offset I think.
I was wondering if these would fit.
Old Aug 21, 2008 | 12:54 PM
  #415
first350's Avatar
first350
I've got RPF1 18X10 +38 - I'm running a 15/10mm spacer to make things fit. (I have F295/35, R315/30's, w/ the fenders rolled)
the RPF1's are hard to beat for how much they weigh/cost
Old Aug 22, 2008 | 05:28 AM
  #416
mario23's Avatar
mario23
Originally Posted by laze1
My square setup (275/40-17 RA1s) is a little "loose" at times...but I use that to my advantage. And I adjust that with tire pressure changes and Sway Bar adjustments...to change behavior.
I currently run my rear sway bar on max-soft, the front bar is one-hole up from full soft...and normally run a 2 lbs lower rear tire pressure. However, This is still a little on the loose-side, but great for HPDE, and just having fun.
But I have now gotten into Time Trials, and will go back to a stagered setup, 275/40-17 and 295/40-17 running Kuhmo 710s. I think this will give me that extra traction/comfort when driving at 100% and more overall speed.
Note: I have the Hotchkis TVS kit, that has adjustable sway bars, and SPL F & R Camber arms, but still run stock shocks.
Hey are you going to be using the same wheels for that staggered setuo?
Old Aug 29, 2008 | 02:08 PM
  #417
ADMAN's Avatar
ADMAN
+1: You just need more seat time to get used to your new setup.
I went square AND one size down from what I was running. My car felt VERY different too.
Felt like I lowered the rear end or something. But, I soon discovered I could:
(1) Maintain A LOT more speed into the turn. Less braking.
(2) Didn't need to worry about the front end push as much. More control.
(3) Could start accelerating out much sooner. Less push also meant straighter exits.
I love the setup. However, now that the car is Supercharged, I'm not sure how this stance is going to feel under WOT.
I will see in October...
Old Aug 30, 2008 | 05:07 AM
  #418
laze1's Avatar
laze1
Yep, 17x10 all around...
Old Sep 2, 2008 | 12:23 PM
  #419
scotts300's Avatar
scotts300
Is that a 15mm spacer for the front and 10mm spacer for the rear? Note your typo - 295/35 --? 295/30. Fronts rolled also, and did you leave the JIC-FLT coilovers for next season?
Old Sep 2, 2008 | 02:42 PM
  #420
first350's Avatar
first350
yep, the 15mm spacer is for the front, and 10mm for the rear.
Front: 295/30/18
Rear: 315/30/18
front aren't really rolled...they rubbed a bit in the beginning during hard cornering - that 'rolled' them enough so that they no longer rub.
still have the JIC-FLT2 coilovers...they're working great - the shocks have no signs of leaking even w/ all of the abuse I've put on them.
**during hard cornering, both front and rear slightly rub on the inside...it's not much, but I can see where the tire makes contact with the interior components.
