The Tire DB - Posts about Track and AutoX tire brands
Old Sep 5, 2008 | 12:33 PM
  #421
AznSky's Avatar
AznSky
Going autoxing again this Sunday so hopefully it'll give me a chance to start playing with tire pressure.
Before I was running roughly 37psi hot all around. Maybe I'll drop the rears down to 35 to see how it feels.
Another comment I got from one of my friends is that since the tires I'm running now were purchased used and the previous owner autoxed a lot, they may have been heat cycled too much to where they're just super stiff with no real traction. This kinda makes sense too.
Old Sep 12, 2008 | 03:00 PM
  #422
mario23's Avatar
mario23
I just wanted to thank you guys (especially axelerate and Laze) for all the great info. I finally got my dedicated track setup and can't wait for Sebring next month!!!
I had a hell of a time finding the wheels as they are on national back order but I was able to grab one of the last sets around directly from 5Zigen...great guys over there. I was also able to find a great deal on the R888's...275/40.
I see what you guys mean about the low clearance of the front uprights. So since you guys have tracked this setup a bit now, I figured I would ask. Should I worry about wheel flex and possibly touching the a-arm? Should I get spacers and if so...which would you all recommend? If I don't need to worry about them, that's fine but I figured you all would probable have input for me.
Thanks again for all your help...
Old Sep 12, 2008 | 06:20 PM
  #423
l30thelion's Avatar
l30thelion
Damn, that looks hot, so jealous. Congrats!
Old Sep 13, 2008 | 05:09 PM
  #424
laze1's Avatar
laze1
[/I]
I run a 3 MM spacers in front.............
Old Sep 14, 2008 | 06:27 PM
  #425
2fast4ya's Avatar
2fast4ya
so Mario, what day are you going to be at Sebring? Jetpilot and I will
be there on Sunday the 5th, i noticed on the roster there was another
Z besides me and him-i guess that's you.
Old Sep 14, 2008 | 07:50 PM
  #426
mario23's Avatar
mario23
I'll be there both days.
Hoping to get my check ride
Old Sep 15, 2008 | 11:03 AM
  #427
scotts300's Avatar
scotts300
So what size and offset did you end up with?
Old Sep 15, 2008 | 02:10 PM
  #428
mario23's Avatar
mario23
17x10 +25
Old Sep 15, 2008 | 04:05 PM
  #429
Axelerate's Avatar
Axelerate
I usually run a 5mm in the front, because I have it.
You could put a piece of tape on the uprights and after a session, jack it up and see if any of it has rubbed off. I don't think it will hit, but it can't hurt to check.
Also, where did you get the tire deal???
Old Sep 15, 2008 | 04:17 PM
  #430
mario23's Avatar
mario23
Got the tires here...
http://www.bobwoodmantires.com/bwttires.php
I'll probably get the 5mm spacers just for piece of mind. It does look damn close and I'm concerned about wheel flex.
Old Sep 16, 2008 | 05:16 AM
  #431
orangeflash's Avatar
orangeflash
hey mario what kinda drop do you have? springs/coils?
Old Sep 16, 2008 | 05:24 AM
  #432
laze1's Avatar
laze1
I run 3MM spacers with stock lugs/studs...if you go with a thicker spacer, you will likely need to change out your lugs/studs.....
3MM
Old Sep 16, 2008 | 02:12 PM
  #433
mario23's Avatar
mario23
3MM
That's a good point. Where did you find 3mm spacers?
Old Sep 16, 2008 | 03:03 PM
  #434
laze1's Avatar
laze1
I don't remember...let me see if I can find the paperwork....but they are not much $$
As usual, just Goggle "3 MM Wheel spacer".......you will need 5x114.3 pattern, and an center hole large enough to fit over the "concentric hub"......
anybody know what size that is????
Old Sep 16, 2008 | 03:58 PM
  #435
mario23's Avatar
mario23
Ok thanks for the info.
It looks like RacingLab has some Wheel Mates so I might give them a call tomorrow.
Old Sep 16, 2008 | 05:51 PM
  #436
350zDex's Avatar
350zDex
OK MY LAST ? HAHA IF I GET 17by9 +15 with 255/40 or 17x10 +25 275/40 WILL I BE FINE IT LOOKS LIKE IT WOULD BE FINE IN THE REAR (IS THERE ANYWAY I COULD RUN +12 IN THE REAR WITH NO SUSPENSION ISSUES IM LOWERED ON TEIN S-TECHS??) JUST WANT A FINAL ANSWER BEFORE I ORDER.
Old Sep 16, 2008 | 05:52 PM
  #437
thinking's Avatar
thinking
66mm (Eibach says 66.1, but there is still a tinsy bit of play)
Old Sep 16, 2008 | 06:00 PM
  #438
350zDex's Avatar
350zDex
HERES A LINK TO THE 3MM SPACER OR THEY HAVE 5MM TOO
http://www.evasivemotorsports.com/Me...ode=T1R_SPACER
Old Sep 16, 2008 | 06:57 PM
  #439
mario23's Avatar
mario23
Those look better...thanks.
What would I do without you guys
I take it centering rings wouldn't work with this setup anymore?
Old Sep 17, 2008 | 04:22 AM
  #440
laze1's Avatar
laze1
It still comes into play with the 3MM, and likely the 5 MM.....
