RPF1's 17x10 +38 all around
If you intend to track the car you will be running at least 2.5 degrees up front anyway, if you're serious about it anyway. It's actually not as bad as you think if you keep the toe near zero. The wear is uneven but I wouldn't say the wear is really that much accelerated.
Plus, the 'HellaFlush' guys on here will give you 'mad props' which you can trade in for new tires later on I hear.
Have to run a max of 225 width on a 10" wheel though
I currently drive a 96 Integra GSR with some cheap Eibach springs which gives me negative camber and uneven tire ware that isn't that bad but i don't think its near -3.00 camber...
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
