Road Racing tire pressure?
Old Nov 6, 2003 | 08:09 AM
Zhenyka's Avatar
Zhenyka
Question Road Racing tire pressure?
Greetings all,
What do you guys recomend for me to set my tire pressure to for the road racing (NOT drag strip )?
The temberature will be 35 - 58 degrees.
I have 18" stock tires.
Also a buddy of mine is going with his Z and he has stock 17" tires.
Let me know what ya thinking.
Old Nov 6, 2003 | 08:15 AM
John's Avatar
John
Which track will you be on? I normally try to shoot for the tires to get around 40-42psi hot... so I'd recommend starting around 32-34 cold...
Old Nov 6, 2003 | 08:36 AM
Zhenyka's Avatar
Zhenyka
Summit Point Raceway.
Thanks for your reply. Would you say 42 front, 40 back, hot is a good setup?
Old Nov 6, 2003 | 08:39 AM
Audito350Z's Avatar
Audito350Z
I agree with John.... I did two weekends at Texas World Speedway with the OEM RE040s and started with 33 front and rear. After a 20 minute session the temps were up to about 41-41.
This is with my Track model Z... and the 18" Rays wheels.
Have fun... and keep the shiny side up
Old Nov 6, 2003 | 09:47 AM
John's Avatar
John
Well, at Summit, you're going to work the hell out of your front left tire, so keep an eye on the wear and psi. I normally try to keep the front and rear the same psi as I find the car is more balanced that way.
You going to be there at FATT tomorrow? I was planning on going, but I have a large deliverable to complete at work tomorrow... oh well. *sigh*
Old Nov 6, 2003 | 10:41 AM
Zhenyka's Avatar
Zhenyka
Yup, I will be at the FATT tomorrow (nov 7th) along with my 3 buddies from work as well as my dad who will drive my Z during a different session..
Sorry to hear to can't make it.
All of us have cameras installed in our cars, so I will post a video from the track after we edit it.
Old Nov 6, 2003 | 11:20 AM
John's Avatar
John
Commasense (James) will be there with his copper Z... stop by and say hello to him...
Old Nov 6, 2003 | 11:43 AM
veeracer's Avatar
veeracer
I have 5 or 6 track days on our Z now and agree that between 40 and 42 hot seems good for the RE-040 tires.
You sound like you may be new to track days, so a word of caution. Watch your brake pads. I have seen Zs use up rear pads in one track day. In 7500 miles I'm on my third set of pads and second set of rotors.
I put Porterfield high performance street pads on and they seem to be a very good comprimise for street and occasional track use.
In a Z, the last turn at Summit Point must a real challenge. Have fun.
Old Nov 6, 2003 | 11:48 AM
Zhenyka's Avatar
Zhenyka
Thanks for all the feedback guys.
I've heard horror stories about breaks fading, and with my dad and myself running two consecutive sessions I will have to keep an eye on the breaks.
Old Nov 6, 2003 | 01:25 PM
EnthuZ's Avatar
EnthuZ
Be VERY EASY ON YOUR BRAKES!
I hope you've changed to a race level brake fluid also.
Your stock rear brakes WON'T last more than 5 or 6 20 minute sessions if you use their capabilities. Try & pick up a spare set.
Besides all that.......have a blast & be careful!
Old Nov 6, 2003 | 04:25 PM
raceboy's Avatar
raceboy
That is how I started out running my Z (when I was on street tires). This had always worked for me on my MUCH lighter cars. Finally someone used to running a heavier car suggested that I lower the tire pressure all around to get it to about 37lbs HOT. I immediatedly went over a second a lap faster on a 2 minute course!
Try both and see how it works.
Old Nov 6, 2003 | 05:26 PM
John's Avatar
John
I'll try what you suggest Steve, but I wonder if that will be the same for when it's in the 30s where the tarmac is much colder. What did you start at cold to get 37psi hot?
Old Nov 6, 2003 | 07:11 PM
raceboy's Avatar
raceboy
Starting at about 28lbs. I usually try to run 1lb higher in the fronts.
Old Nov 7, 2003 | 03:13 AM
John's Avatar
John
No unusual tire wear at all? I would worry that the outside of the tires would wear prematurely...
Old Nov 22, 2003 | 09:49 AM
Bubba1's Avatar
Bubba1
At Summit Point , I've been running 40psi cold in the front and 39cold in the rear. Handling felt sloppier to me at 32psi cold. And the left front tire definately wears faster than the others at Summit Point. Brakes too. I also use DOT4brake fluid.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
