race car hood pin recommendation
Old Oct 19, 2010 | 02:43 PM
laze1's Avatar
laze1
Default race car hood pin recommendation
This isn't a ricer question
I need to install hood pins on my race car, and looking for something durable, and will work on a stock but kinda bent hood and front end and can withstand a few "love-taps" from racing
Plus I take my car apart all the time after track fender-benders and to do maintenance.
I have seen these around but wonder how much trouble they create when the get out of alignment???
Anybody us these successfully?
http://www.deftracing.com/aerocatch_...od_latches.htm
Or should I just go with Old-School hood pins??? (much cheaper)
http://www.sparcousa.com/ptuning_acc.asp?id=297
http://www.streetsideauto.com/produc...GoogleShopping
Old Oct 19, 2010 | 04:28 PM
terrasmak's Avatar
I would go with the old school version. Much easier
Old Oct 19, 2010 | 04:47 PM
zaperroni's Avatar
zaperroni
You can't really go wrong with sparco
Old Oct 19, 2010 | 05:14 PM
Any club restrictions as to the type style pins you can use?
And these (4) will be the only means of holding the hood shut?
Old Oct 19, 2010 | 05:22 PM
laze1's Avatar
laze1
No and Yes (2 pins w/no safety latch)
Old Oct 19, 2010 | 05:34 PM
This pin is pretty cool with plenty of height adjustment. Should suit your needs.
Old Oct 19, 2010 | 07:26 PM
redman333's Avatar
redman333
I have had the aero catch pins on my hood for awhile and have never had any issues with them. One thing that I did notice but it never happened with me is that if you ever closed the latch it could stay shut but not click in and under load while driving it could put open being that they are spring loaded. However if you get the one with the key then it shouldn't be a problem.
Old Oct 20, 2010 | 03:31 AM
laze1's Avatar
laze1
Excellent point...so I am going "Old School" for safety
Old Oct 20, 2010 | 05:00 AM
mhoward1's Avatar
mhoward1
Another adavantage of the old school ones is the pit marshals can easily check to see if the pins are in and locked.
I have personal experience in this now.
Old Oct 20, 2010 | 06:56 AM
laze1's Avatar
laze1
LOL!!!
I saw some post that indicated that you had a recent experience with "hood-to-car-connectivity"
Old Oct 20, 2010 | 06:58 AM
mhoward1's Avatar
mhoward1
Good news is a FFRC hood can also act a airplane wing and glide pretty darn well.
Old Oct 20, 2010 | 08:36 AM
laze1's Avatar
laze1
I should have said:
I saw some post that indicated that you had a recent experience with LACK OF "hood-to-car-connectivity"
LOL!!!
Old Oct 20, 2010 | 08:40 AM
mhoward1's Avatar
mhoward1
yeah,
so does anyone know where I can find bright red hood pin clips?
Old Oct 20, 2010 | 11:04 AM
laze1's Avatar
laze1
I received some good info here...THNX TO ALL!
So, I will be going "old School" hood pins....
Old Oct 22, 2010 | 10:15 AM
ADMAN's Avatar
ADMAN
I run these. I had to modify the post. It is now hinged. Perfect...
Old Oct 22, 2010 | 01:23 PM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
I just ordered the old school Sparco ones, 35 bucks, hard to beat. I am going to retain the factory latch though. Happened twice to me where I almost ran over a hood that flew off someones car. Silver hoods on asphalt at 100+ kind of blend in with each other lol...
Old Oct 22, 2010 | 01:33 PM
laze1's Avatar
laze1
I recommend that you remove the stock hood release hardware on a 100% dedicated race car. The reason is that if you have a fire, say an engine fire, after you bail out of the car and run as far away as possible, the safety crews will not be able to get your hood open to address the fire.
The safety crew will not expect you to have both hood pins AND a hood latch.
Just my opinion...
Old Oct 25, 2010 | 05:12 AM
ThreeFiveZero Z
^ Thats a good point, I hadnt given it much thought. Thanks!
Old Oct 25, 2010 | 06:00 AM
laze1's Avatar
laze1
Installed my hood pins this weekend, and ditched the OEM hood latch hardware...also duct taped over the hood latch opening to improve air flow into the Rad.
Note: i will fabricate something over the winter, but duct duct will work for now
Old Oct 25, 2010 | 06:28 AM
ThreeFiveZero Z
Did you go with the sparcos? Easy install?
