Time Attack Build
Old Dec 11, 2010 | 03:47 PM
kparlett's Avatar
kparlett
Default Time Attack Build
Parts are finally coming in for the build of the NOS Energy Drink / SOHO Motorsports G35 and im gonna make a new thread and update for anyone interested during the build. (Im doing it on a couple sites). Here is the almost finalized list and there are still a few things to add. Also there are a few teaser pics and links to the blog and facebook.
Blog - http://kparlettracing.blogspot.com/
Facebook - http://www.facebook.com/profile.php?id=100001789426064
#144 Infiniti G35
Sponsors: SOHO Motorsports / NOS Energy / Assaultech / GTSpec / Computech / STS Turbo / SPL Suspension
#144 Time Attack G35 - Current Modification List (3/24/11):
Engine & Drivetrain:
· JE Pistons 96mm 8.5:1
· Eagle Connecting Rods
· Cometic .70mm Thick Head Gasket for 96mm Overbore
· ACL Main and Rod Bearings
· ARP Main, Rod and Head Studs
· Nissan Engine Assembly Seal And Gasket Kit
· CJ Motorsports Dual 255 lph Fuel Pump Assembly
· AAM Oil Pan Spacer Kit
· Block and Head Port and Polish
· STS Remote Mount .68mm Ball Bearing Ceramic Turbo
· STS Electronic Boost Controller, Intercooler & Piping
· Turbosmart Ultragate 38mm 5 psi Wastegate
· Turbosmart Blow Off Valve 52mm Black
· Osiris UpRev Engine Management
· HKS EVC VI Electronic Boost Controller
· Deatchworks 800cc Injectors
· Walbro 255 lph Fuel Pump Kit
· Brian Crower Camshafts Stage 2 – 264 Turbo Spec
· Brian Crower VQ Single Spring & Titanium Retainer Kit
· Exedy Twin Carbon Clutch and Flywheel
· Quaife ATB Differential Mechanical Open Type
· Driveshaft Shop Level 5 Axles
· Cosworth Carbon Fiber Intake Manifold
· Cosworth High Volume Fuel Rail Kit
· GTM 13 Row Oil Cooler Kit
· Greddy 15mm Light Weight 1000ml Oval Catch Can
· Mishimoto Low Temp Thermostat 62 deg
· Koyo V-Core Radiator
· ATI Super Damper VQ35
· Strup 3-1 Headers
· Top Speed Race Pipes
· Top Speed Y Pipe
· Samco Radiator Hosing
· B&M Short Shifter
· NGK Iridium Plugs
· Agency Power Steel Braided Clutch Lines
Suspension & Brakes:
· KW Suspension Custom Club Sport Racing Coilovers
· Wilwood 6 Piston 14" Front Big Brakes
· Wilwood 4 Piston 13" Rear Big Brakes
· GTSpec Front & Rear Strut Bar
· GTSpec Front & Rear Tie Brace
· GTSpec Rear Lateral Arm Brace
· GTSpec Mid Chassis Brace
· SPL Front Upper Control Arms V3
· SPL Solid Front Lower Arm Bushings & Shock Mount
· SPL Solid Front Compression Rod Bushings
· SPL Front Outer Tie Rod Ends
· SPL Solid Rear Knuckle Monoball Bushings
· SPL Solid Differential Mount Bushings
· SPL Rear Camber Links
· SPL Adjustable Endlinks Front and Rear
· Stillen 35mm Front Sway Bar
· Stillen 27mm Rear Sway Bar
· Stillen Engine Damper
· Intec Racing Differential Brace
Interior & Exterior:
· Computech DataMaxx LCD Data Acquisition System
· Volk TE37 SL Wheels 18 x 10.5 +22 F, 18 x 9.5 +15 R
· Toyo R888 Tires 305/35R/18 Rear, 285/35R/18 Front
· APR 67” GTC-300 Carbon Fiber Adjustable Rear Spoiler
· Tom Pallatin Motorsports Roll Cage
· Sparco Evo & Evo 2 Seats and Brackets
· Sparco Ring Suede Steering Wheel
· Sparco Carbon Pedal Set
· Sparco Steering Wheel Quick Release
· NRG Short Steering Wheel Hub Adapter
· ARC Aluminum Radiator Cap
· Greddy Radiator Cap
· Strafe Speed Kuruma Z Poly Front Bumper
· Strafe Speed Carbon Fiber V1 Rear Trunk
· Strafe Speed Impul Poly Sideskirts
· D5 Racing Carbon Fiber Front Grill
· GTSpec Air Diversion Panel
· Billet Aluminum Gunmetal Tow Hooks
· Southbend Clutch Aluminum Shift **** w/ Set Screw
· G Force 3in. 5 pt Seatbelt Harness Black
Teaser Shots:
We will be doing the build at SOHO Motorsports in Charlotte, NC over the next 8 weeks so there will be a lot more updates soon!
Old Dec 11, 2010 | 03:49 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default Sexy...
time.
- RB.
Old Dec 11, 2010 | 04:03 PM
kparlett's Avatar
kparlett
the rest of the part should be here next week so there will be a ton of stuff coming soon. Check out the blog and fb for the time being!
Old Dec 11, 2010 | 04:45 PM
03threefiftyz's Avatar
03threefiftyz
Definitely things that I would change in terms of parts, but I wish you good luck. In for updates as they come along.
Old Dec 11, 2010 | 10:47 PM
terrasmak's Avatar
I would ditch the SPC control arms and get SPL, ditch the Nismo bushings and get SPl, add a set of Whiteline Subframe bushings and make sure you get Wilwood Poly H pads for the front, Poly B will be fine for the rear.
Old Dec 12, 2010 | 01:46 AM
zerosec's Avatar
zerosec
amazing !
why don't u go with UPREV instead of cobb ?
G/L !
Old Dec 12, 2010 | 01:49 PM
reserved's Avatar
reserved
Same question here.......just wondering because I was thinking Uprev, but my nearest Uprev dealer is 4 hours away.
Old Dec 12, 2010 | 01:55 PM
03threefiftyz
Agreed....not even cobb themselves support it.
Old Dec 12, 2010 | 02:02 PM
terrasmak's Avatar
Actually they just don't sell it anymore. They still support it. Also trackside support ? Uprev raced how many Time Attack events and had trackside support for their customers? How about Cobb? I know Cobb was at every event i was, and helped me out if i needed it!!
Old Dec 12, 2010 | 02:20 PM
03threefiftyz
I stand corrected....I know Uprev supports Sfarrah in his ST2/3 car with NASA.
Old Dec 12, 2010 | 03:04 PM
TAHorizon's Avatar
TAHorizon
What time attack series are you entering into? There are no Redline events scheduled on the east coast for 2011...
Old Dec 12, 2010 | 03:26 PM
kparlett's Avatar
kparlett
amazing !
G/L !
Cobb is currently on the car as it is now, notice the utec on the list as well. We will be switching to the utec or haltech and not use Uprev or Cobb. I like the cobb for low end stuff but not a full race setup
Old Dec 12, 2010 | 03:28 PM
kparlett's Avatar
kparlett
SPL has good parts, not bad like I previously said (i refered to the wrong company) and thats why this post has been edited
Old Dec 12, 2010 | 03:30 PM
kparlett's Avatar
kparlett
Yes you are correct unfortunately Redline has put there east coast operations on hold for 2011, so our plan is to build the car now, do a ton of testing and a lot of regional/ east coast events and then by the end of 2011 start doing the Redline swing on the west coast when the car is ready. The real goal is to run the full Redline series in 2012.
Old Dec 12, 2010 | 03:31 PM
03threefiftyz
I have never had any issue getting a hold of SPL. If you are settled on either Utec haltech.....I'd take the haltech. Are you going to run NASA, EMRA, or....? Just curious.
Old Dec 12, 2010 | 03:48 PM
kparlett's Avatar
kparlett
We have a few local series here in charlotte but ill be doing track events all over from Atlanta, CMP, CMS, VIR, Summit, and everywhere else on the east. Il prob do the occasional NASA even and since ive done a fair bit of autox in the past i may do a few national events with SCCA as well... working on the official schedule when everyone else releases event dates.
Old Dec 12, 2010 | 03:53 PM
03threefiftyz
Which SCCA region do you run? You going to run SSM or XP? Maybe I will see you around at Summit, etc.
Old Dec 12, 2010 | 05:17 PM
kparlett's Avatar
kparlett
Well I ran the DC Region (Autocrossers Inc) in 2009 and won the F Stock championship when the G was stock and this year I ran in Central Carolina and South Carolina region and won a ton of races in FS and in STX. Once the car is built it will be a Street Mod car but it wont ever be too successful at a national level in autoxing, the car just isnt built for it and the setup we are putting on the car will be for track use not low rpm autox, but it will still be fun lol. If there is a race ill pretty much be at it.
Old Dec 12, 2010 | 05:18 PM
kparlett's Avatar
kparlett
Oh and ill def be at Summit dont worry lol. Hyperfest is already on the calendar along with some other events
Old Dec 12, 2010 | 05:43 PM
03threefiftyz
I just did an AI event last year, but the lot in Waldorf is too far. I just looked through the results....I guess you were excluding the guys that ran the "pro" class.....because the GT-C's of Burns and Piccone seemed to be 6-8 seconds quicker. Those guys run at a national level though.
I'll keep my eyes peeled for you.....
I won BSP (including the pro's) the only one I attended in Oct. Fun group.
