portable tire inflator
Old Feb 24, 2011 | 10:06 PM
JDMStanced's Avatar
JDMStanced
Default portable tire inflator
I attempted to search but not many were found.
What do you guys use for portable tire inflator?
I'm looking for one around $20 that has coiled hose which has the chuck thing at the end, and connects to either battery or cigarette lighter.
Homedepot has Goodyear i3000 12v tire inflator for $19. Dunno if I should go for it or look around more for coiled hose andbetter look lol
thanks
auto stop feature would be nice
Old Feb 24, 2011 | 10:45 PM
terrasmak's Avatar
Bigger the better, sucks waiting around for 20 minutes per tire.
Old Feb 25, 2011 | 02:21 AM
mhoward1's Avatar
mhoward1
The Goodyear i7000 is pretty good. Another option is a 140 PSI air tank you can recharge at home or at a shop...or a portable 120V 2 or 5 gallon compressor for about $50 bucks
Old Feb 25, 2011 | 02:31 AM
JDMStanced's Avatar
JDMStanced
the first time i looked at i7000, it was the one i was looking for but too expensive for a tire inflator. What do you think about i3000?
What brand do you recommend for small air tanks?>
Old Feb 25, 2011 | 03:34 AM
$20 will get you what you need. THe clip-on feature for the valve stem is smart: it takes a while to add, say, 5 PSI.
Old Feb 25, 2011 | 03:40 AM
JDMStanced's Avatar
JDMStanced
brand name please~
Old Feb 25, 2011 | 04:01 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I keep this in my glove box. $20 at Advance Auto.
Old Feb 25, 2011 | 04:35 AM
sanford's Avatar
sanford
^ I own one, those are not bad for when your in a pinch.
Old Feb 25, 2011 | 04:55 AM
laze1's Avatar
laze1
I have a BMW 328i with Run Flats, so I carry one of these in the trunk. This one has a long hose and DC cables...
http://www.walmart.com/ip/Slime-Flat...r-Kit/14254126
They have many options, from cheapo to decent...
http://www.walmart.com/search/search...h_constraint=0
Old Feb 25, 2011 | 05:19 AM
mhoward1's Avatar
mhoward1
The biggest issue with the 12V ones is time. Because the flow rate is so small it takes forever just to bump 2 to 5 psi in a tire.
For air tanks I would look at the Northern Tool and Harbor Freight brands. They will work just fine as long as you stay 10+ PSI under their max.
Old Feb 25, 2011 | 08:16 AM
AJCaron12's Avatar
AJCaron12
I use a $90 digital Matco one. But you kinda need a nice expensive one when you work in a garage I guess.
Old Feb 25, 2011 | 08:26 AM
Jennifer 2's Avatar
Jennifer 2
All those 12-volt compressors take forever to add a couple of pounds of pressure to four tires. I use my bicycle floor pump (pumps air about 10 times faster). My bike has a small frame pump on it for roadside repairs, but I keep a large floor pump in the garage and it does double duty for bikes and topping up the cars.
Old Feb 25, 2011 | 01:30 PM
arsey51's Avatar
arsey51
Pep Boys, Auto Zone, or check out Wal-Mart link from laze1, they have what your looking for priced at 19.00.
Old Feb 25, 2011 | 01:35 PM
mhoward1's Avatar
mhoward1
http://www.northerntool.com/shop/too...9119_200319119
Old Feb 25, 2011 | 01:44 PM
brand name please~
http://www.safety-devices.com/pump_9815.htm
Old Feb 26, 2011 | 11:09 PM
JDMStanced's Avatar
JDMStanced
i ordered Q industries HV35
Old Feb 28, 2011 | 01:09 PM
ADMAN's Avatar
ADMAN
I've been pretty happen with mine so far.
Heavy Duty. 12v. 150psi. Not too bad...
Old Feb 28, 2011 | 02:05 PM
JDMStanced's Avatar
JDMStanced
emmm i want that coil hose.
Do you use the cigarette lighter or converted to battery connector?
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
