lets see your autoX/Track wheel and tire setups
Old Jan 28, 2014 | 10:58 AM
  #201
Colombo's Avatar
Originally Posted by SE5spd
Why do you want 315 square and why 315 on 10.5" wheel?
I'm trying to go with as large of a square setup as I can get away with. Why not? Car destroys rear tires and would be nice to rotate, I would also like to try a square setup from all the good I have read.
Old Jan 28, 2014 | 05:46 PM
  #202
Lubo's Avatar
Lubo
You should be running between 11.5" to 12" wide wheel to make those fit and perform better. What kind of suspension set up you are running?
Old Mar 24, 2014 | 04:33 AM
  #203
Erajk's Avatar
Erajk
Ugly Dotz Hanzo, plasti-dipped with 265/35-18 Federal 595RS-R around!
Aiming for RPF1 with Kumho V70a 265 around next season
upload image online
free screen capture software
Old Aug 15, 2014 | 12:32 AM
  #204
joshua350z6841's Avatar
joshua350z6841
new set up 18x11 295 a6
Attached Thumbnails lets see your autoX/Track wheel and tire setups-4532.jpg   lets see your autoX/Track wheel and tire setups-458.jpg   lets see your autoX/Track wheel and tire setups-4542.jpg
Old Aug 22, 2014 | 12:37 PM
  #205
Everet Hampton's Avatar
Everet Hampton
I was under the impression that 315 was ok on a 10.5 tire rack shows 10.5-11.5 I believe. Would a 295 work? I'm currently on 285s on a 10 in tire with No issues
I run a 315 on 10.5 RPF. No problems
Old Sep 24, 2014 | 08:31 PM
  #206
jdmlove1's Avatar
jdmlove1
i have square setup wheels 9.5 +12
i am planning to go with RS3 265-40-18 all around, am lowered on tein s-tech and want a new grippy tires for autox.
anybody running same setup?
Old Sep 25, 2014 | 08:21 PM
  #207
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ I have that in the front and 285s for the rear. I've run 285s in the front, too, but you need good bit of camber and/or the front fenders pulled.
Old Sep 26, 2014 | 03:38 AM
  #208
03threefiftyz's Avatar
03threefiftyz
Old Sep 26, 2014 | 05:35 AM
  #209
jdmlove1's Avatar
jdmlove1
^^ nice photos, yesterday i was watching few of your videos on Youtube.. you really pushing this z to the limits
Old Sep 30, 2014 | 09:32 AM
  #210
Veridisquo's Avatar
Veridisquo
Hey guys, new to the forums. My first instinct was to come check out what you guys like as far as track setups go!
I looked around quite extensively but couldn't find a definitive answer. What do you guys recommend on tire sizes for an NA z33? Seems like a majority run 265mm widths at the minimum front and rear. Are most of the engine setups here NA? Please share, it would help me and I hope others greatly thanks
Old Sep 30, 2014 | 12:22 PM
  #211
gabez33's Avatar
gabez33
great photos!!!
Old Sep 30, 2014 | 10:19 PM
  #212
superlim9's Avatar
superlim9
Looking good! whats the offset if you don't mind me asking
Old Sep 30, 2014 | 10:25 PM
  #213
superlim9's Avatar
superlim9
I run a 275 square setup and it's a lot of rubber for mine with only intake, exhaust, and plenum spacer.
Some of the guys like Scotts300 have said that anymore then 285 for NA street car is overkill. After going 275 i tend to agree... and i'm on hard cheapo rubber until summer.
Old Oct 1, 2014 | 05:44 AM
  #214
03threefiftyz
I have bolt-ons and 315's on all 4....true story. It feels under-tired at times in autox.
Old Oct 1, 2014 | 06:40 AM
  #215
terrasmak's Avatar
265 to 285 is on target for roadcourses, autocross seems to need more mechanical grip. I currently run 285's and am dropping down to 275's for the next set of tires.
Old Oct 1, 2014 | 11:58 AM
  #216
Veridisquo's Avatar
Veridisquo
Since joining the forum, I've seen a lot of your insightful information! Your car looks nuts! Hope to join some of the guys on here in STU in the next couple years.
Thanks for the input guys, appreciate it. Was worried about understeering issues with wide tires on a mostly NA. Coming from stock tire sizes, I'll try upping to 265 all around.
Mods currently are: Lightweight flywheel, 3.9 final drive NISMO diff set to 1.5way, and Greddy exhaust. The final drive and diff are quite enjoyable
Old Oct 29, 2014 | 02:20 PM
  #217
crZydave's Avatar
crZydave
New setup is 17X9 Enkei RPF1 with 255/40/17 Maxxis RC1 tires. Saving a bundle on tires.
Old Nov 5, 2014 | 04:33 PM
  #218
SE5spd's Avatar
SE5spd
RC1 are rad.
Old Nov 6, 2014 | 04:57 PM
  #219
joshua350z6841
22 front an rear
Old Nov 6, 2014 | 07:05 PM
  #220
joshua350z6841
i am sure u mean that at a stock power level an at a higher one say 400hp at the rear a larger tire would be useful
