lets see your autoX/Track wheel and tire setups
Old Jan 19, 2013 | 07:29 AM
  #121
03threefiftyz's Avatar
03threefiftyz
Win. They are here...
Old Jan 19, 2013 | 08:47 AM
  #122
misterniceguy's Avatar
misterniceguy
Oooh, nice. Specs?
Old Jan 19, 2013 | 08:48 AM
  #123
03threefiftyz
18x11 +13
18x12 +19
Old Jan 19, 2013 | 11:11 AM
  #124
misterniceguy
Nice. What tires are you going with? Please post pics on car when you get them on. I predict awesomeness.
Old Jan 19, 2013 | 11:17 AM
  #125
03threefiftyz
Same as last year....315 Hoosier A6 on all 4. May give the BFG R1S's a shot for testing if they ever release the 315/30/18.
Old Jan 19, 2013 | 07:29 PM
  #126
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Those are teh sex!
Old Jan 19, 2013 | 08:32 PM
  #127
PDX_Racer's Avatar
PDX_Racer
Can't comment on whether you need a small spacer or not....have to have someone else chime in. You can't adjust camber in C-stock. My guess is the 295 in front will rub a little bit. I am not 100% sure the 315 will fit in back without a roll, which I doubt highly is stock legal. You may have to run 295 square.
295 A6s *barely* fit in front with the OEM v1 track wheels (which are marginally wider at the lip), but they do clear.
295s is what I run, and have had a moderate amount of success with them.
Old Jan 19, 2013 | 08:46 PM
  #128
SE5spd's Avatar
SE5spd
Mike = insane baller!
Old Jan 20, 2013 | 01:18 PM
  #129
ldstang50's Avatar
ldstang50
Very nice Mike.
Why are you going to run the BFG's when Hoosier offers contigency? Or you just going to test them out?
Old Jan 20, 2013 | 02:11 PM
  #130
03threefiftyz
BFG has a better contingency actually for solo. I will run whatever is faster...particularly at Nats.
Old Jan 20, 2013 | 04:52 PM
  #131
IM3H's Avatar
IM3H
The stock Nismo rims are 18x9 and 19x10. I was thinking about 255 for the front and 295 rear. The 295 might be a stretch for an 9" rim.
Old Jan 20, 2013 | 05:24 PM
  #132
PDX_Racer's Avatar
PDX_Racer
If you're running A6s in autocross, get as much tire as you can get. The 295s have only a bit of challenge fitting, but even the local tire shop has had very few problems mounting the 285 A6s on my front (18x8) rims, and the rears are even easier.
Personally, I'd try 285/30R18 for the front (I'd be afraid that the 9" rim is going to allow the fronts too close to the front suspension without spacers) and 315 for the rear -- BUT, I'd find someone who had some old, worn-out tires of the size I wanted to try (locally, if possible, so that I wouldn't pay a lot in shipping) and mount and test-fit the tires before committing to a size that might not work.
I don't like spacers so I probably won't go larger than 295 on the front of my car, and I like the square stance since that helps to eliminate some exit understeer.
(Oh, and my comment about my "moderate success" was sarcasm -- people seem to know that if I show up in my car and I'm even moderately prepared for the event, that I'll likely be contending for the win.)
Old Jan 20, 2013 | 06:37 PM
  #133
IM3H's Avatar
IM3H
I can only change the offset by .25 inches to stay In stock. It looks like the 285 on a 10" rim has a tread width of 10.9 and the 255 on a 9" rim has a tread width of 10.8. I am assuming the specs that Tirerack is posting is fairly accurate. Looking for the pros on fitment advice.
I am hoping that that A6s will rachet up my placement in the standings. I have been within 2 seconds of top times on street tires this past year and most times every one ahead of me had better rubber.
Old Jan 22, 2013 | 06:34 PM
  #134
jarrodh77's Avatar
jarrodh77
For what it's worth, the 2012 STR national champ (Lugod) tested the BFG vs A6 back-to-back on a BSP S2000 and found the BFG to be .6 sec faster.
Old Jan 22, 2013 | 07:04 PM
  #135
03threefiftyz
Yes, I know. BFG doesn't make a size for us yet. I am talking with Pete Calhoun of BFG about trying to get an early set for testing. I had a small test day with Junior Johnson, Strano, etc and they ran a bunch of testing on the vettes. Inconclusive, but the BFG has raw speed. It is more difficult to control at the limit though.
Old Feb 13, 2013 | 06:13 PM
  #136
joshua350z6841's Avatar
joshua350z6841
Anyone running nt03 size an offset want to know what to buy
Old Feb 14, 2013 | 06:00 PM
  #137
terrasmak's Avatar
Goals, tire size etc etc.
Old Feb 14, 2013 | 06:02 PM
  #138
joshua350z6841
275 front an 275 to 295 rear
Old Feb 14, 2013 | 06:59 PM
  #139
terrasmak's Avatar
Just get the 9.5 and 10.5 combo
Old Feb 14, 2013 | 08:38 PM
  #140
joshua350z6841
I like the idea of square to rotate them
