Looking for Input on a Starting Setup
Old Sep 30, 2011 | 06:54 PM
sanbaifo's Avatar
sanbaifo
Question Looking for Input on a Starting Setup
I plan to use the car mostly for track days, autocross and some drifting. It'll probably end up being a "jack of all trades, master of none" but I should get a lot of seat time. I also plan to drive it to events as far as 3 hours away; sometimes more.
It currently has:
front adjustable a-arms
coilovers 10k/10k
Hotchkis 3-way adjustable sway bars
1.5 way clutch LSD (80%)
18x9.5 30mm offset wheels
Front lip
Adjustable rear wing
I am planning on running 140 treadwear 265/35-18 all the way around and hoping that I can use the sways, tire pressures, and shocks to fine tune. For drifting, I'll just put some old 245/40-18's on some spare wheels to burn them off.
What I'm wondering is how feasible my plan sounds and some starting alignment specs.
Thanks!
Old Sep 30, 2011 | 08:21 PM
INTIMAZY's Avatar
INTIMAZY
You should be golden with that setup.
The only suggestion would be to invest in a good set of coilovers or konis. Not sure what brand you were looking at.
-2.5 front camber with 1/16 out on toe
-1.75 rear camber with zero toe
Should be a good place to start with a street/track setup keeping in mind the 150+ mile one way trips you would be doing.
If you have a dedicated set of tires then you can ramp up the front camber to -3 and the rear up to -2.5 (some people prefer less rear camber but for NA Z's I prefer big rear numbers)
Old Sep 30, 2011 | 10:40 PM
terrasmak's Avatar
Is the car your daily driver ?
Old Oct 1, 2011 | 04:19 AM
sanbaifo's Avatar
sanbaifo
No, it isn't my daily.
Old Oct 1, 2011 | 05:26 AM
sanbaifo's Avatar
sanbaifo
I'm running JIC FLTA2. Will I need to add rear camber arms to adjust the rear?
Old Oct 1, 2011 | 06:00 AM
INTIMAZY's Avatar
INTIMAZY
You will need camber bolts and toe arms for the rear. Well, that's the most cost effective option anyway.
Old Oct 1, 2011 | 08:12 AM
terrasmak's Avatar
Since it is not a daily, this will work pretty good. But you do want 1/16 toe in on the rear. If you were to remove drifting from the equation, i would say -2.1 to -2.2 rear camber.
Old Oct 1, 2011 | 01:35 PM
This is quite a compromise. If its on the street than it must be licensed and street legal. That said you might consider a hitch and trailer for competition tires.
Old Oct 3, 2011 | 10:15 AM
sanbaifo's Avatar
sanbaifo
Thanks for the input.
I was thinking about running NT01's and that's what came on it (staggered) but I figure for the first year, I'll be learning the car and want to make things as simple a possible.
Old Oct 13, 2011 | 05:12 PM
sanbaifo's Avatar
sanbaifo
Are the toe figures per side or total?
Do you think I will need camber bolts to get the -1.75* camber in the rear?
Thanks!
Old Nov 16, 2011 | 03:32 PM
cbasil's Avatar
cbasil
I would get rid of those FLT-A2's. I have them on my car now, and after my 2nd SCCA event. Both rears blew with only 15,000 miles on them. Sorry, didn't mean to burst your bubble. I am looking around the autocross thread for new suspension setups.
Old Mar 9, 2012 | 03:12 PM
sanbaifo's Avatar
sanbaifo
Old Apr 23, 2012 | 02:20 PM
sanbaifo's Avatar
sanbaifo
Well, I took it to get it aligned and confimed that I do need to add some camber and toe adjustability to the rear in order to get my desired specs.
Is the Eibach kit sufficient? Or do I have to worry about slippage?
I also saw that Kinetix offers a Camber & Traction/Toe set up that includes ES bushings and is supposed to allow some toe adjustment via the traction arms.
SPL is out of my range.
350Z_Al
Oct 29, 2020 07:44 PM
