The 2TH PWR Track Car conversion
Old Jul 25, 2013 | 02:37 PM
  #621
Sickboy101's Avatar
Sickboy101
Great to hear Mike!
Old Jul 25, 2013 | 05:00 PM
  #622
nissannx's Avatar
nissannx
Perhaps when you were on the dyno the heat just robbed the car of power. Spring session versus summer heat wave?
Old Jul 25, 2013 | 05:20 PM
  #623
2TH PWR's Avatar
2TH PWR
^That's what Sasha says.. but I'm not convinced entirely. Session two was with bigger injectors, bigger fuel pump, upgraded MAF and 1000 more rpm programmed in.
How can temp get rid of 35 hp with better equipment?
Also, the car is trapping out all the straight aways at almost the exact same speeds as last year? Maybe I need to just drive awesomer. I'm tempted to just 1/4 mile it with no aero to see if it traps higher in keeping with the hp. Cheapest and most objective way to test that I can think of.
Old Jul 25, 2013 | 07:34 PM
  #624
2TH PWR's Avatar
2TH PWR
Well there were a few cars that dyno'ed less than expected. So maybe I'm just a whiner
Old Jul 25, 2013 | 08:12 PM
  #625
Wu-Watt's Avatar
Wu-Watt
I watched a vid of a dude from R-Magic talking about a quad rotor RX-7 they built and it took them 2 years just to start the thing. (Japan)
Talk about dedication.
Old Jul 26, 2013 | 09:52 AM
  #626
jamestown's Avatar
jamestown
Isn't the dyno the most objective way? Quarter mile still has a lot of variables.
Possibly take it to the aph dyno on a cooler day to see it it just the weather or sasha's most recent dyno?
Old Jul 26, 2013 | 10:22 AM
  #627
2TH PWR's Avatar
2TH PWR
Oh yes. I just mean the most objective of what I have available
Old Jul 26, 2013 | 11:43 AM
  #628
GT-Rob's Avatar
GT-Rob
Have you tried giving it full throttle?
Old Jul 26, 2013 | 12:57 PM
  #629
2TH PWR's Avatar
2TH PWR
Yes. And making sure the throttle body was opening all the way was one if the things Sasha checked
Old Jul 26, 2013 | 02:55 PM
  #630
Smasher's Avatar
Smasher
Leak down and compression tests passed with flying colours!!! Weird!!!
But good and cheaper
Just curious did they give you a reading for each cyl and what was it for the leak down test?
Old Jul 26, 2013 | 03:24 PM
  #631
Wu-Watt's Avatar
Wu-Watt
Try throwing money at it literally. It might come around. Everyone has their price.
Old Jul 26, 2013 | 04:19 PM
  #632
2TH PWR's Avatar
2TH PWR
I
I think on the tester they had they read 140 psi on every cylinder.
I'm not sure if that is correct. He just said "every cylinder is 140 bang on"
Old Jul 26, 2013 | 04:40 PM
  #633
XChacalX's Avatar
XChacalX
I
140psi ? seem low , unless its the result of those big cams that has quite a bit of overlap.
What did Sasha said about this ?
Old Jul 26, 2013 | 05:53 PM
  #634
2TH PWR's Avatar
2TH PWR
He said it seems great that they are all the same. He never did the test so there is no comparison.
Old Jul 26, 2013 | 06:19 PM
  #635
Smasher's Avatar
Smasher
I
That's for a compression test though the leak down test measures leakage.
A leak down or "cylinder leakage" test is similar to a compression test in that it tells you how well your engine's cylinders are sealing. But instead of measuring pressure, it measures pressure loss.
A leak down test requires the removal of all the spark plugs. The crankshaft is then turned so that each piston is at top dead center (both valves closed) when each cylinder is tested. Most people start with cylinder number one and follow the engine's firing order.
A threaded coupling attached to a leakage gauge is screwed into a spark plug hole. Compressed air (80 to 90 psi) is then fed into the cylinder.
An engine in great condition should generally show only 5 to 10% leakage. An engine that's still in pretty good condition may show up to 20% leakage. But more than 30% leakage indicates trouble.
The neat thing about a leakage test (as opposed to a compression test) is that it's faster and easier to figure out where the pressure is going. If you hear air coming out of the tailpipe, it indicates a leaky exhaust valve. Air coming out of the throttle body or carburetor would point to a leaky intake valve. Air coming out of the breather vent or PCV valve fitting would tell you the rings and/or cylinders are worn.
A leakage test can also be used in conjunction with a compression test to diagnose other kinds of problems.
A cylinder that has poor compression, but minimal leakage, usually has a valvetrain problem such as a worn cam lobe, broken valve spring, collapsed lifter, bent push rod, etc.
If all the cylinders have low compression, but show minimal leakage, the most likely cause is incorrect valve timing. The timing belt or chain may be off a notch or two.
If compression is good and leakage is minimal, but a cylinder is misfiring or shows up weak in a power balance test, it indicates a fuel delivery (bad injector) or ignition problem (fouled spark plug or bad plug wire).
Old Jul 26, 2013 | 06:27 PM
  #636
2TH PWR's Avatar
2TH PWR
This was theorized by another person. As a result of a high rev, nothing was physically damaged, but skipped a notch on the cam timing.
Old Jul 27, 2013 | 01:14 PM
  #637
OPSash's Avatar
OPSash
Big cams will cause the compression at cranking to be much lower than stock. I don't think the valve timing is off.
Old Jul 29, 2013 | 04:05 AM
  #638
2TH PWR's Avatar
2TH PWR
Car ran really great! Sounded meaner than ever, and I would say felt like it had lots of power. I'm leaving it like this. This was the most trouble free the car has been in a long time. Just smooth sailing.
Old Jul 29, 2013 | 08:45 AM
  #639
GT-Rob's Avatar
GT-Rob
That is awesome Mike, car sounds like a monster.
How do you like DDT now? Its not as fast as tmp but I always found it more entertaining with the elevation changes. Could use a repave at the bottom though.
Old Jul 29, 2013 | 09:17 AM
  #640
2TH PWR's Avatar
2TH PWR
Yeah everyone was coming over and saying the car sounded awesome. Sounded like an animal.
DDT is a lot of fun. But it's a very small very tight track and no one got any clean laps in practice it seemed. Everyone was complaining about it. I only turned 15 laps in practice and I'd say I maybe had 1 or 2 laps that were pretty wide open.
The other problem is sharing with the drifters. They toss dirt everywhere. And one drifter lost his oil drain plug. So there was a track of oil all across the highside of the track where the drifters play. In retrospect it didn't give me too much trouble but I found it did rob my confidence for a lot of the day because I didn't want to wreck my splitter.
There were a couple cracked up time attack cars that I saw. Slippery track.
