The 2TH PWR Track Car conversion
Old Apr 18, 2014 | 01:18 PM
  #721
KingBaby's Avatar
KingBaby
Hardest Setting
always awesome stuff
Old Apr 18, 2014 | 06:20 PM
  #722
joshua350z6841's Avatar
joshua350z6841
great numbers. good work an love the details
Old Apr 22, 2014 | 06:12 PM
  #723
2TH PWR's Avatar
2TH PWR
I had my first shake down of the season. Well I had time to review the data. And, the verdict is in. The car is dramatically faster than 2013. For some reason the best lap I can find is a 1:18.51. But I swear I saw a 1:17.9 flash up? But who cares. Front straight speeds were up to 183.6 from last years best 179.1. So Sasha's tuning knowledge pays off again. But here is the good part, at least to me. Peak grip is down on the tires to a max of 1.26 lateral G. I set those numbers with Hankook RS3s. When I set a 1:18.4, with a fastest rolling lap of 1:17.55 at CSCS4 in 2013 I was setting peak grip of 1.53 consistently. And even then the tires had been used 6 track days. I just wasn't used to R comps previously. So I am eager to get a fresh set of rubber on. In the end, at my power to weight ratio, and those grip levels I think the time is pretty great.
So this is based on grip and power to weight the best technical performance to date.
I just didn't have enough tire to break my overall PB. You can really see the difference new springs make in the handling traits of the car.
2014 Season Stats: 312 rwhp. 1440kg 3175 lbs race weight with driver.
Changes from 2013: Power increase from 280 rwhp to 312 rwhp.
Increase in suspension spring rate from 7K to 12.5K with revalve of Koni Yellows. Not corner balanced.
Slightly heavier due to esthetics and safety. 4 Point roll cage.
Goals.
TMP less than 1:17 in good conditions.
GBR less than 54 in good conditions.
DDT ?????
Road Atlanta Global Time Attack: Don't wreck car, try not to get last place in the Limited Division.
Tire and money permitting do some OTA events and Mosport GP.
Old Apr 22, 2014 | 07:25 PM
  #724
2TH PWR's Avatar
2TH PWR
Old Apr 24, 2014 | 03:52 AM
  #725
2TH PWR's Avatar
2TH PWR
This is a great chase video from both perspectives.
The turbo Miata put down a 1:20.0 while chasing me. My data was somehow corrupt while running away.
Old Apr 27, 2014 | 04:48 AM
  #726
2TH PWR's Avatar
2TH PWR
Old Apr 29, 2014 | 06:30 PM
  #727
Wu-Watt's Avatar
Wu-Watt
What does the car weigh now?? Seems like it's pretty much worked out this year eh? Chassis wise, I mean. Looks better.
Your 1:18 looks easy, I think there's more in those tires. Advans?
Old Apr 29, 2014 | 06:51 PM
  #728
2TH PWR's Avatar
2TH PWR
The stiffer springs made a difference. Less squirmey.
This is on end of life R comps. Street tire grip levels.
I think on fresh r comps it will be flirting with 1:16s
Just my predictions.
1:18s weren't easy. I was going ***** to the wall. The car is just less dramatic. I would say 1:20s were easy. 1:19's were good. 1:18s required max effort and no mistakes. max grip from data was only 1.26G which is low.
Old Apr 30, 2014 | 06:58 PM
  #729
Wu-Watt's Avatar
Wu-Watt
Cool so 2900 n change. When I said it looked easy I meant you did it easily, not that I could easily do that time.
I agree with fresh rubber and warmer ambient temp you'll put down faster times.
What brake rotors do you have? Did I ask you that already? lol
You should get a cf hatch and a lexan window.
Old Apr 30, 2014 | 07:14 PM
  #730
Emski's Avatar
Emski
Do you know any of the specs on the Miata? Sounds like it's understeering.
Old Apr 30, 2014 | 07:24 PM
  #731
2TH PWR's Avatar
2TH PWR
I know, and I'm just saying, it wasn't easy for me. I have the power slot rotors.
I would get CF and Lexan, but classing. Maybe next year.
Old Apr 30, 2014 | 07:25 PM
  #732
Wu-Watt's Avatar
Wu-Watt
$hit i just read the post about the new intake making lots of jam thats awesome.
Im going to reconsider doing that. In reality I think the cats and intake are the most important for hp gains and the intake was made to fit the car not to make the most hp. It's way restrictive imo. 40hp gain is huge!
*The Aero rotors will save you some more weight too. When the power slots are toast. Gotcha on the cf and lexan.
Old Apr 30, 2014 | 08:34 PM
  #733
2TH PWR's Avatar
2TH PWR
Miata was on low boost. 9 psi 205 rwhp. 2400 lbs with driver.
Old May 3, 2014 | 04:01 AM
  #734
Smasher's Avatar
Smasher
Good luck next weekend Mike. We should have a z meet at your awesome 2th pwr race shop (garage as a send off.
Old May 3, 2014 | 05:03 AM
  #735
Canada_Z's Avatar
Canada_Z
I believe he is down in Atlanta right now.
Old May 11, 2014 | 05:24 PM
  #736
GT-Rob's Avatar
GT-Rob
Mike its time for a new profile pic I think That car is not the same, bling wheels and body kit, who WAS that??
The car is incredible and you have come a long way as a driver. Glad you to see you pushing the car and yourself!
Old May 11, 2014 | 06:21 PM
  #737
2TH PWR's Avatar
2TH PWR
just some quick clips from a friend of day 1 while I work on a video.
Old May 11, 2014 | 07:31 PM
  #738
Emski's Avatar
Emski
Sounds awesome! I see you are still running with no rear bumper. Any plans on making a rear diffuser?
Old May 12, 2014 | 04:52 AM
  #739
2TH PWR's Avatar
2TH PWR
Yes I'll make a carbon diffuser at some point.
But here is my main video from Road Atlanta.
Same thumbnail because it's my coolest pic for now.
Old May 12, 2014 | 11:19 AM
  #740
Blurvision's Avatar
Blurvision
Really nice video, thanks for sharing. How was the road trip for you? Talk about an amazing experience for it all. The final turn onto the start / finish takes some serious ***** to get right, no runoff there at all. Major respect to you for going so far to compete.
