Homemade Splitter Design and Mounting
Old Jun 11, 2013 | 02:18 PM
  #121
2TH PWR's Avatar
2TH PWR
I just noticed you did that too. I also made a shroud on the inside to act like poor mans ducting to force air only to the radiator and oil cooler. Will try and get pics. I am not sure what angle is on the APR but I think it's the same. Least aggressive angle so far.
Old Jun 24, 2013 | 02:02 PM
  #122
2TH PWR's Avatar
2TH PWR
Made some adjustments! Front grip is now INSANE. Much better than before. I put it on with no other changes other than lowering it, and the car had massive oversteer. Like terrasmak I had to increase the rear wing angle to try and balance it out.
It's also built like a tank. Survived two offs, with only a broken/ lost bolt that holds the main support onto the splitter itself. This is under heavy braking.
Old Jun 24, 2013 | 06:21 PM
  #123
terrasmak's Avatar
I don't remember what coilover you have but, if you have an adjustable body, slightly extend it to reduce up travel. If you have non adjustable body like mine, install a thicker bump stop , I just put some in mine , they engage 3/4 inch before the car bottoms out , the add 100lb of spring rate when they engage. You may also benefit from stiffer springs too. I have yet to test, but I went from a 700lb to 736lb front spring.
Old Jun 24, 2013 | 07:26 PM
  #124
2TH PWR's Avatar
2TH PWR
I'm still just on off the shelf Koni yellows and swift spec r springs. 280-450 lbs progressive.
Old Jun 24, 2013 | 08:51 PM
  #125
terrasmak's Avatar
Dam, you really need stiffer springs. I don't know if you can add a larger bump stop with those shocks, maybe TrueChoice Koni can help. Send them in, revalve and get springs. I would really say 11k or up to about 650lb front and rear , those shocks from what i understand cant handle much more spring (even with the revalve)
Old Jun 25, 2013 | 12:58 AM
  #126
mw9's Avatar
mw9
I am also on Konis yellows, I have a set of NISMO(NISSAN) T2 springs laying around. My understanding is they are around 600lbs, I work right next to Konis and was going to get them revalved this winter, you think not worth it?
Old Jun 25, 2013 | 05:15 AM
  #127
terrasmak's Avatar
690lb f/r for the t2 springs. You can try, cant think of the name on here, but they could never get them to not blow when valved properly for higher spring rates.
hulkout
Tuning
Sep 30, 2015 12:33 PM
Dymsi
Sep 29, 2015 11:32 AM
