Homemade Splitter Design and Mounting
Old Apr 26, 2013 | 11:47 AM
  #101
Zazz93's Avatar
Zazz93
Cool work folks.
Old Apr 26, 2013 | 04:32 PM
  #102
terrasmak's Avatar
<a href="http://www.flickr.com/photos/61208532@N05/8685015268/" title="Untitled by terrasmak, on Flickr"><img src="http://farm9.staticflickr.com/8396/8685015268_25517812e9_c.jpg" width="800" height="600" alt="Untitled"></a>
All together, next i will remove the canards, probably one set at a time for testing.
Old Apr 26, 2013 | 04:38 PM
  #103
2TH PWR's Avatar
2TH PWR
my god i love the flap in front of the wheel. I was thinking of doing the same thing. does it shield the wheel from the front as well? more detailed pics from other angles?
What support rods are those?
Old Apr 27, 2013 | 12:17 AM
  #104
terrasmak's Avatar
They completely cover the front of the tire. You can see where i rivited in the backets to the bumper where they are held on, just a simple 90 degree aluminum bracket then they are bolted to the bracket, i used aviation style nutplates on the back of the brackets.
The support rods are just 1/4 hiem joints, available at my local hardware store for about $6 each, then 1/4-28 allthread cut to length. The lower mount point is 90 degree 1/8 aluminum , the upper is 1/16 steel angle cause i needed the strenght when making the mount about 1 inch off the bumper.
Also in the pic, i blocked off the outer sections of the radiator opening for better aero. I used 1/16 aluminum for it, that section is lined up with the core support, no need for air to hit the core support. Brake ducts will be mounted in the blockoff at a later date. http://www.aircraftspruce.com/catalo...uctflanges.php is what i'm using , the same flanges will be rivited to the OEM brake backing plates.
Old Apr 28, 2013 | 03:35 AM
  #105
Fixxxercask's Avatar
Fixxxercask
Well done sir. Looks much cleaner than mine. I also like the "flap" around the wheel well.
Old May 28, 2013 | 10:59 AM
  #106
2TH PWR's Avatar
2TH PWR
mine is almost complete,
going to make some shrouding to stop air from going straight out the wheel wells. might make some side spats. but good to go and passed 200 lb test and run to 200 kmh / 120 mph at the airport on sunday.
the beauty of it is how easy it is to put on and off. it's held on my 8 bolts that go where the crash beam mounts to the chassis. so 8 bolts and one bolt for the main support rod. there are two claw like metal pieces welded to the frame at the back and the splitter just slides into it like resting on a shelf at the back.
So it comes on and off to go on the trailer.
Old May 30, 2013 | 10:08 AM
  #107
2TH PWR's Avatar
2TH PWR
So I just weighed the entire splitter system including brackets and supports. 31.8 lbs which is heavier than I would have liked. But used steel for the uprights. So it is making the car about 0.125 seconds per lap slower based on weight. Hopefully the car is faster than that based on aero benefit.
Anyone else weigh their set ups? Let me know if you include the crash beam or not.
Old May 30, 2013 | 11:12 AM
  #108
Chebosto's Avatar
Chebosto
can you stand on it and not have it break?
Old May 30, 2013 | 11:18 AM
  #109
KingBaby's Avatar
KingBaby
Hardest Setting
do you have pics of someone actually doing that?
Old May 30, 2013 | 11:52 AM
  #110
Chebosto's Avatar
Chebosto
here is Steve Mitchell's Z.
this is how you do it.
Attached Thumbnails Homemade Splitter Design and Mounting-40881_158022160888684_2611845_n.jpg   Homemade Splitter Design and Mounting-62380_157578160933084_4927947_n.jpg   Homemade Splitter Design and Mounting-62380_157578144266419_939949_n.jpg   Homemade Splitter Design and Mounting-62053_157578104266423_4087133_n.jpg
Old May 30, 2013 | 12:37 PM
  #111
SE5spd's Avatar
SE5spd
^ but can a FAT person stand on it, and have it not break is the real question lol
Old May 30, 2013 | 01:51 PM
  #112
Fixxxercask
My splitter and air dam weighed about 16lbs. If you include all the hardware and such it still would not be more than 20lbs. I can stand on mine and jump up and down on it. I weigh about 165lbs.
Old May 30, 2013 | 06:57 PM
  #113
2TH PWR's Avatar
2TH PWR
Yeah I can stand on mine as well. The splitter weighs 12 pounds.
It's the steel plates that make it bolt on that make it a bit heavy. But I am not running the crash beam.
Old May 30, 2013 | 07:34 PM
  #114
KingBaby's Avatar
KingBaby
Hardest Setting
So gonna play stupid....
you only have to be able to stand in the middle?
Old May 30, 2013 | 10:01 PM
  #115
terrasmak's Avatar
No need for it to be that strong
Old Jun 3, 2013 | 10:12 AM
  #116
Chebosto's Avatar
Chebosto
i would say strong enough to handle 100+# downforce at least w/o warping or bending.
Old Jun 10, 2013 | 12:59 PM
  #117
2TH PWR's Avatar
2TH PWR
First test of the splitter in action.
Needs a bit more work, but overall it held up well.
Old Jun 10, 2013 | 07:20 PM
  #118
Z33_Taxi's Avatar
Z33_Taxi
Did you find it helped at all? I follow you on FB and youtube(so much hate about the class you're racing in)
I know you were saying it had to be at a 0* angle to the ground
Old Jun 11, 2013 | 04:00 AM
  #119
2TH PWR's Avatar
2TH PWR
Hey! Yes I see you on there Phil. I am not sure how much it helped because the first day I used it was also the first day
I ran with r compounds. It's still being over powered by the apr wing. I left the suspension settings the same to get a feel and now I have understeer vs before it was perfectly balanced. So going to make some adjustments to both the splitter and the suspension and see how it goes
Old Jun 11, 2013 | 08:36 AM
  #120
terrasmak's Avatar
Looks like you blocked off the outer parts of the Nismo bumper like i did.
How much wing angle are you running? I run between 2 and 4 degrees up on the center section.
