2013 Spec Z Rules suggestions
Old Dec 17, 2012 | 01:58 PM
laze1's Avatar
laze1
Default 2013 Spec Z Rules suggestions
Alrighty Kids, it is time to start Bitchin' & Moaning about rules...
Post up whatever you want, and I will send it to the Spec Z leadership Folk
My Spec Z 2013 rules suggestion in no particular order:
add rule that allow for drilling/cutting hole in rear strut brace to enable adjustments to the top of the Damper without having to remove the Damper from the car
add rule that allow for drilling/cutting hole in front strut bar to enable adjustments to the top of the Damper without having to remove it from the car (in fact you cannot install the KW front dampers without either cutting the mounting studs or making a hole in the strut bar for them to pass through to allow the OEM strut to be reinstalled correctly
allow for 18x10 wheels on all 4 positions
MAKE DE ENGINE CARS BASE WEIGHT 3200
MAKE REVUP ENGINE CARS BASE WEIGHT 3300
MAKE HR ENGINE CARS BASE WEIGHT 3450 AND/OR RUN A RESTRICTOR
Allow for battery relocation to any safe location
That is all I can think of today....
Old Dec 17, 2012 | 02:03 PM
laze1's Avatar
laze1
Scott wants better Trophy's
Old Dec 17, 2012 | 02:39 PM
Jagerz's Avatar
Jagerz
Great thread. I hope we can get the battery relocation mod to improve corner weighting ability.
Old Dec 17, 2012 | 04:06 PM
03Z33's Avatar
03Z33
All of yours plus:
Allow Nismo or other LSD
Allow alternate spring rate/length with the KW setup
Old Dec 17, 2012 | 04:08 PM
terrasmak's Avatar
Front camber arms
Diff bushing
Old Dec 17, 2012 | 05:17 PM
03threefiftyz's Avatar
03threefiftyz
IMO, the top priority should be to get rid of wavetrac in favor of a nismo or other clutch type diff.
Old Dec 17, 2012 | 06:44 PM
jblz's Avatar
jblz
This is one.
My other suggestion for consideration is allow replica-made nismo aero (for non-Nismo editions).
This is only a suggestion for consideration. I think the Wavetrac issue and others are more important.
Old Dec 17, 2012 | 07:06 PM
terrasmak's Avatar
Originally Posted by jblz
This is one.
My other suggestion for consideration are 1) allow replica-made nismo aero (for non-Nismo editions).
Actually I think Nismo V1 and V2 should be allowed , also in replica form
Old Dec 17, 2012 | 08:16 PM
dkmura's Avatar
dkmura
General & DIY Moderator
I'd like to see the BFG spec R1 changed to allow up to a 285/30-18 tire. Won't cost much more, but will be more durable.
Old Dec 17, 2012 | 09:21 PM
Jagerz's Avatar
Jagerz
Agree. Priority should be on changing lsd above all.
Old Dec 17, 2012 | 10:10 PM
R350Zz33's Avatar
R350Zz33
Originally Posted by laze1
[B]
you de guys really need that much of an advantage over us hr guys u jump it up 100 lbs for the rev up and 150 more for the hr y not another 100 or just 50 its only 6 hp more
Old Dec 17, 2012 | 10:25 PM
SE5spd's Avatar
SE5spd
go away
Old Dec 17, 2012 | 10:27 PM
SE5spd's Avatar
SE5spd
10" - agreed
285 R1 - agreed
nismo/other clutch type diff - F YES agreed
NISMO V1-3 bumper allowed - agreed
A arms - agreed
all good things to put into consideration to make the class that much better
Old Dec 18, 2012 | 01:49 AM
laze1's Avatar
laze1
Greetings!
Old Dec 18, 2012 | 12:15 PM
Fixxxercask's Avatar
Fixxxercask
I agree with everything so far. Especially for the diff to be open, 18x10 all around max and front upper A-arms.
Old Dec 18, 2012 | 12:22 PM
pchio's Avatar
pchio
1) ABS Delete
2) LSD
3) Wheel size
4) alternate spring rate for KW, especially for the rear.
5) Front Camber arms
Old Dec 18, 2012 | 04:19 PM
laze1's Avatar
laze1
17 Brake System
ABS delete is already legal...
17.1 Brake System
a) Brake pads are unrestricted.
b) Brake rotors must be the same type, material, and dimensions as OEM. Brake rotors from
alternate companies may be used. Brake rotors may be cryogenically treated.
c) Steel braided brake lines may be used.
d) Disc brake backing plates may be removed.
e) The emergency brake level and/or cables and associated must remain functional.
f) Anti-lock braking systems (ABS) may be disabled.
g) Nissan Motorsports front brake cooling kit part # may be utilized.
Originally Posted by pchio
1) ABS Delete
2) LSD
3) Wheel size
Old Dec 18, 2012 | 05:12 PM
pchio's Avatar
pchio
I see! However, is brake bias valve legal given that we need someway to adjust the brake bias?
Old Dec 18, 2012 | 05:26 PM
laze1's Avatar
laze1
Excellent Question..I will ask NASA to clarify that..and hopefully state that in the rules
Old Dec 19, 2012 | 02:05 AM
mhoward1's Avatar
mhoward1
I would suggest put your request in priority order
