I use Stoptech ST40 front and stock non-brembo rear with Hawk HP+ all round. After 5 track days and couple autox, I replaced them to ferodo pads. I noticed the rear pads almost worn out however the front may last two more track days. Is this normal and why?
Also want to ask a question for brake duct. I diyed brake duct by using a 3” duct, I was wondering if it is too big to use in cold weather (in Sept/Oct)? Does too much cold air will mess up the rotor on track?
Thanks in advance!
I think your car has a brake design issue...the rears are working WAY TOO HARD.
hmmm. design issue? MC and booster are OEM. when I hard brake from 120 to 70, the back of the car felt stable. Do you think if I do hard brake from 50 to 0 and see if rear will lock first will help to tell whether too much bias to the rear?
