It's time: BSP Solo car to NASA TT3 Build
Old Aug 12, 2015 | 08:19 AM
  #141
terrasmak's Avatar
Thought about it and I actually have a pair of ones from Penske, but I don't like the idea of the weight being largely on the center of the mount with that solution. Honestly, I measured the ride height and it is about where it was before and the wheel rate is higher now, so I'll toss it on the scales in a few weeks and see where it is. If it has to go up more than a 1/4" on the drivers side I will probably have to do that.
But without them you put a nice side load on the shock shaft thru out the travel
Old Aug 12, 2015 | 08:35 AM
  #142
03threefiftyz's Avatar
03threefiftyz
I'm not sure the difference in side load is that great, but I'll play around with it.
Old Aug 17, 2015 | 02:31 PM
  #143
SirMichael's Avatar
SirMichael
What is the size of the storage unit you are working out of?
Old Aug 17, 2015 | 05:18 PM
  #144
03threefiftyz
20x12.5'....ish is expensive in the greater DC area. Oh well. No power, but I have a 3000w generator inverter that supplies power for everything I need (up to 140amp welder).
Old Aug 18, 2015 | 07:14 AM
  #145
DmanG281's Avatar
DmanG281
I will never complain about the size of my garage again.......
Old Aug 18, 2015 | 09:41 AM
  #146
03threefiftyz
Yup, but I built a many times winning national level BSP car in a driveway for years...so this feels like a palace. Do the best you can with whatcha got, man....
Old Sep 14, 2015 | 10:03 AM
  #147
03threefiftyz
It's unlikely the car will run this year. Just had to dump $6000 into my truck (trans died and injectors). I will hit the ground running in March of 2016, though.
Debating a few different potential paths: Regardless of path I am swapping the used up Cusco to an OSG and the hopefully a few hours in a wind tunnel to fine tune the aero.
1) Swap to Sequential trans (hit on p/w modifier) and find creative ways to get more weight out. Leave the motor alone and stick with 275 A7's.
2) Top end rebuild along with revup oil pump and rod bolts to try and get to 325whp...preferable without ethanol to get there and stick with 275 A7's.
3) Focus on getting weight out and run real slicks (probably medium compound pirelli's). Also spend a bit more to maximize the aero.
4) Something I think of later.
Old Sep 14, 2015 | 11:44 AM
  #148
AceInHole's Avatar
AceInHole
At least you know your shocks still work :P
Old Sep 14, 2015 | 11:46 AM
  #149
03threefiftyz
Did you put in n20 at nats? I never asked...
Old Sep 15, 2015 | 08:22 AM
  #150
AceInHole's Avatar
AceInHole
Nope. Probably should've for the west course... it was super bumpy.
Old Sep 18, 2015 | 05:05 PM
  #151
03threefiftyz
Anyone want a Kirk Roll Bar? $450 picked up in MD. Harness never mounted, etc. I'm going to ahead and have the car caged. I want to gut the doors, get rid of glass, etc but can't door that without the full cage. Probably also get rid of the speaker box crap that I had left in there for additional rigidity. Goal weight should be about the same as with full doors, speaker box and the roll bar.
Old Nov 8, 2015 | 12:31 PM
  #152
03threefiftyz
Haven't done a thing the past 3 months on the car, but bought a quickjack and tested it out. Other than that, just got the shocks back in and the car on the ground. The next month will be spent getting every ounce out and getting the car down for the cage in 4 weeks. Even on the shortest rubber pucks it's a good height to work on it from underneath.
Old Nov 9, 2015 | 05:11 AM
  #153
hajwoj's Avatar
If you don't mind, which version of Quickjack did you get?
Old Nov 9, 2015 | 06:31 AM
  #154
03threefiftyz
Just the 3500. The car only weighs 2800lbs. We'll see how it does with the Focus ST here shortly. If I did it again, I would probably get the 5000 for the wider footprint.
Old Nov 24, 2015 | 05:46 AM
  #155
03threefiftyz
Does anyone have experience with the Megan RCA's? Off the shelf options are limited for roll center adjustment....the other option looking much the same in terms of material but 3x the price. Thanks.
Old Dec 16, 2015 | 04:31 PM
  #156
03threefiftyz
She's finally seen daylight and now down in VA for the cage at Piper...
Old Jan 5, 2016 | 01:37 PM
  #157
03threefiftyz
Cage done:
Old Jan 5, 2016 | 02:19 PM
  #158
Blurvision's Avatar
Blurvision
Looking good! Any more detailed shots? Happy with how it came out?
Old Jan 5, 2016 | 03:05 PM
  #159
03threefiftyz
Don't pick it up until Saturday, so more pics then.
Old Jan 11, 2016 | 05:26 AM
  #160
03threefiftyz
Everything starts going back together starting this week. Still have to parse through the wiring and get a bit more of the sound material off the trans tunnel, but other than that it is just putting it all back together and fabbing some of the stuff for the aero and exhaust. WILL be on track March 12-13 .
