It's time: BSP Solo car to NASA TT3 Build
Old Jan 11, 2016 | 07:24 PM
  #161
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Can't wait to see it in action!
Old Jan 17, 2016 | 02:29 PM
  #162
03threefiftyz's Avatar
03threefiftyz
New Hood:
Rear Bumper Cut and Lights Back In:
Probably cut out the area where the license plates goes to help get some of the air out that pools up back there as well. Still need to cut/gut the headlights and finish the bracing for the splitter. Should have most of the base exterior stuff done by the end of the week. Have a lot still to do with the wiring, a bit more sound material, etc on the inside. Then the very fun task of painting the cage...which I am dreading. After that I will go back to the exterior to figure out the diffuser and some extra stuff for the front.
Old Jan 17, 2016 | 08:50 PM
  #163
terrasmak's Avatar
I may have to cut my rear bumper out like that
Old Jan 18, 2016 | 04:35 AM
  #164
03threefiftyz
It's sort of a cheater way to get a bit of the air from pooling up behind the wheels, etc while I figure out the diffuser.
Old Jan 19, 2016 | 03:41 AM
  #165
03threefiftyz
Been a while since I updated this....but here's a parts list so far:
Full Parts List:
Engine-
Amsoil Filter w/Custom Velocity Stack
Z1auto 3” MAF Housing
Samco 80mm Intake Tube
Motordyne 5/16” Spacer
Tomei V2 Headers
Z1Motorsports 2.5” Test Pipes
Motorydne XYZ Pipe w/Straight Pipe
JIC 3” Full Titanium Exhaust w/Resonator
OEM GTR Injectors
Deatchswerks 255lph Fuel Pump
2lb Li Battery
Uprev Tuned by Hills Garage
Suspension:
Penske 8300 Remote Reservoir Shocks-True Rear
1000/450 Springs - To start (Imagine this will have to be bumped up)
SPL Front Camber/Caster Arms
SPL Front Compression Rod, Lower Control Arm and Shock Bushings
SPL Front End Links
Hotchkis Front Sway Bar
SPL Rear Traction, Toe and Camber Arms
No Rear Sway Bar
Whiteline Diff Bushings
Brakes:
Stoptech 332mm Front Brake Kit w/2 Piece Rotors
3” Front Brake Ducting
St43 Raybestos Front Brake pads
OEM Brembo Rear Brakes w/2 Piece Rotors
ST42 Raybestos Rear Brake Pads
StopTech Brake Lines
Drivetrain:
OS Giken Super Single Aluminum Clutch
Cusco RS 1.5way Diff
Z1Motorsports Diff Cover
Wheels/Tires:
18x10.5 Enkei RPF1’s – Dry
275/35/18 Hoosier A7 – TT3
275/645/18 Pirelli Slick – UTCC
17x10/11 Forgelines – Wet
275/35/17 Hoosier H.20 - Wet
Interior:
Piper 8pt Roll Cage
Cobra Seat (Soon to replace with HNR)
Scrothe Harness
Sparco Steering Wheel
NRG Quick Release Hub
RacePak IQ3 Digital Dash
Fully Gutted Doors/Dash/Rear Speaker Box
Exterior:
Nismo V3 Front Bumper
Custom DiBond Splitter
Custom Front Fender Extensions
Custom Front Canards
CWest Vented Hood
Brooks Pro Elite Carbon Rear Wing
Modified Rear Bumper and Custom Rear Diffuser
Old Jan 19, 2016 | 04:53 AM
  #166
Flier129's Avatar
Flier129
Everything starts going back together starting this week. Still have to parse through the wiring and get a bit more of the sound material off the trans tunnel, but other than that it is just putting it all back together and fabbing some of the stuff for the aero and exhaust. WILL be on track March 12-13 .
Nice! So coming to Road Atlanta for the SE/MA NASA event on those dates? I'll be there in the miata in TTE, Cathers should be coming down with his TTB M3 as well.
Old Jan 19, 2016 | 05:02 AM
  #167
03threefiftyz
Probably not. I'll shake down the car 40 mins from home at Summit Point the same weekend. Don't like the idea of dragging the car down to ATL when it hasn't run in 18 months and is bound to have some teething issues.
Old Jan 19, 2016 | 01:43 PM
  #168
03threefiftyz
Wheels are in...
Old Jan 22, 2016 | 04:38 AM
  #169
03threefiftyz
Was hoping to make some progress this weekend, but 3'+ of snow on the way may hamper things.
Old Jan 22, 2016 | 03:40 PM
  #170
3hree5ive0ero
Retired Admin
...sounds like an excuse..
Lol jk, I just want to see this car in action is all.
Old Feb 5, 2016 | 02:32 PM
  #171
reserved's Avatar
reserved
Now that you are fully caged, why not race in ST3 this year. A lot of guys are leaving GTS3 to move to ST3, so should be a lot of fun!
Old Feb 6, 2016 | 04:44 AM
  #172
03threefiftyz
Mainly spending the year getting everything working. Will double dip in 2017.
Old Feb 6, 2016 | 06:23 AM
  #173
reserved's Avatar
reserved
Makes sense! Looking forward to seeing the car
Old Feb 10, 2016 | 11:33 AM
  #174
bigjussin's Avatar
bigjussin
looking like a beast! pics of the splitter?
Old Feb 10, 2016 | 12:32 PM
  #175
Flier129's Avatar
Flier129
Mike, you have a lot of time with the car on hoosiers. Have you had any issues with your wheel bearings and what brand have you replaced them with?
Old Feb 11, 2016 | 03:50 AM
  #176
03threefiftyz
Not yet, but maybe next weekend. At this point, the pics might be on hold until until it is largely buttoned up. First event is only a few weeks away, assuming it isn't snowed out.
Believe it or not....I have not changed them since I bought the car in 2006. That is a lot of HARD miles in BSP trim. I have spares, but the bearings still spin great and have no wobble. They'll be in the truck if they need to be replaced on site.
Old Feb 11, 2016 | 08:36 AM
  #177
Flier129's Avatar
Flier129
WTF! Lucky I suppose, that and nissan developed some damn good hubs/bearings.
Well the rear bearings in my car are shot. No wobble, but it's got a bad noise coming from them that goes with wheel speed and gets louder with load. I think I'm guna do the same route I do with miata(s).... timken bearings/hubs stuffed full of AMSoil synthetic grease.
Old Feb 11, 2016 | 10:19 AM
  #178
christoc's Avatar
christoc
I replaced the LF WB on mine after picking it up from Brian, wouldn't pass MO safety until I did
Old Feb 12, 2016 | 04:35 AM
  #179
Fixxxercask's Avatar
Fixxxercask
I've had very good luck with the Nissan wheel bearings as well. I thought for sure after I started running A6s, they would get destroyed shortly thereafter, but I've only had to replace one in 5 seasons of running on A6s. I guess Nissan made a great wheel bearing.
Old Feb 13, 2016 | 05:23 PM
  #180
3hree5ive0ero
Retired Admin
+1 on the great bearings. I've put quite a bit of track, autox, and daily miles on my Z at 176K and I've only had to replace the rear driver's side bearing so far.
