Stock looking custom switch to really turn OFF VDC
Old Jan 14, 2020 | 04:28 PM
Zyko's Avatar
Zyko
Default Stock looking custom switch to really turn OFF VDC
Long time lurker here. Finally made an account, this is my first post
At a few track days i noticed that even with the VDC turned off it intervenes in long sweepers and if i take the curbs harshly. There are three options to turn the VDC completely off
1. Pull the fuse (but also kill ABS)
2. Unplug Yaw Sensor (kinda permanent)
3. Install a switch (that's what I did)
I found a switch that is advertised for different Nissan models, just not for the 350Z, but it looked so similar that i took the chance and ordered it. It fit perfectly fine in the center console. Not sure if i am allowed to post links to products, will do an edit if allowed.
Anyway, installation was relatively easy. Needed a relay though to have the VDC Off when the switch is on and illuminated. That is not needed, i just wanted it that way. Also this is a switch that latches into position. No need to remember to turn of VDC before every Autocross run or track day session. So many times i have started an autocross run just to realize in the first turn that i forgot to turn VDC off, so I have to do it while driving. Needless to say that's dangerous and slows me down. Now with this switch i turn VDC off in the morning and turn it back on when i am driving home.
I hope this helps some racers out there. Let me know if you have any questions.
Wiring and relay fits under center console
custom switch installed
custom switch illuminated
wiring diagram
Old Jan 14, 2020 | 04:51 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Love the label/graphic on the switch.
Good info. I know there's a few threads here that discuss "VDC off for real" but this looks like a really easy/clean way to go.
And yes, a link is fine since everyone is going to ask for it anyways....
Old Jan 15, 2020 | 05:28 AM
iideadeyeii's Avatar
iideadeyeii
Love the diagram. Good work. I just unplugged sensor because I never want it on
Old Jan 15, 2020 | 06:43 AM
GreyZ's Avatar
GreyZ
Yeah, can we get a link for that switch. This looks super nice.
Old Jan 15, 2020 | 01:35 PM
Zyko's Avatar
Zyko
Here the link: https://customswitches.com.au/produc...o-suit-nissan/
They are in Australia, so keep shipping cost and time in mind.
You might have also noticed that the colors are switched. They immediately sent me a new one when i showed them. I just haven't installed the replacement switch yet.
Old Jan 16, 2020 | 11:21 AM
Heel Til I Die's Avatar
Heel Til I Die
Originally Posted by Zyko
Nicely done! Did you use T-taps for the right or left seat switch for power and ground? In the pic above, it looks like the VDC OFF switch is illuminated and so is the seat warmer switch on the right but not the left. Is it just the lighting? Maybe a wire got cut instead of spliced?
Old Jan 20, 2020 | 06:13 AM
Zyko's Avatar
Zyko
I soldered everything. also added a small 2 pin connector for the power coming from the body to the relay and going to the yaw sensor. That way I can easily unplug the Center console if I need to take it out.
I took that picture of the illuminated switches on the bench with a power supply hocked up to only 2 of them. In the car all 3 are working as expected.
97mx5
Jun 17, 2007 08:40 PM
Skittle_Z
Jan 28, 2006 09:39 AM
njsho
Aug 25, 2005 03:23 AM
Z BOY
Feb 21, 2005 03:50 PM
DrCold
Jan 8, 2003 01:31 PM
