DIY License Plate Light Change
Old Oct 17, 2011 | 12:42 PM
  #41
RMichael's Avatar
RMichael
Originally Posted by BonesZ33
if you need a diy to change these bulbs, you shouldn't be touching your car. No offense to the OP.
Since the thread was bumped I read it and this was very funny to me.
Old Jan 9, 2012 | 05:38 PM
  #42
jose18's Avatar
jose18
Just changed mine. Its a nice inexpensive mod thats makes a good difference.
Old Dec 7, 2012 | 03:41 PM
  #43
westfl350z's Avatar
westfl350z
Thanks for a good post-only problem I'm having is that the bulb housing may have warped over time-I got an '04-might be able to extend the little tab that sticks out(the little tab that's on the opposite side of the v-shaped clip on the housing-I might get a little piece of hard plastic+crazy glue it on the bottom of the little tab to make it work-it's just not secure as it was before-
Old Dec 9, 2012 | 09:00 AM
  #44
F2CMaDMaXX's Avatar
F2CMaDMaXX
It's nice and easy to do, but looked like some people had some very dim LED's back when this thread was created.
Old Mar 21, 2015 | 12:09 PM
  #45
dSpaceman's Avatar
dSpaceman
Just did mine, looks great
Just an FYI, you don't actually need a flat head to pry open the housing. It was designed to pop out if you push it to the right and pull.
Old Feb 19, 2016 | 10:30 AM
  #46
Dekker001's Avatar
Dekker001
I swapped out my entire light housings for pre-builds with 16 white led's in each. Lights up the entire back of the car now. Only got pulled over once. Cop said I was illuminating my license TOO well. I never removed the bulbs, just went by to get the fix-it ticket cleared in broad daylight and they cleared it.
Old Feb 19, 2016 | 12:30 PM
  #47
dcains's Avatar
dcains
I've had LEDs in mine for several years, but went with the dimmest white ones I could find. Similar to original bulbs, but whiter. No point in attracting attention or making the rear plate too easy to see, As an aside, I would never be stupid enough to tint heads, tails, signals, reverse lights, etc.
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
