DIY-install shift knob
Old Jul 23, 2009 | 07:27 PM
  #121
MrCrispy's Avatar
MrCrispy
I did mine over the weekend. Channel locks on both, and a rag over the shift **** to try and protect it. Took a ^*(% load of turns to remove it fully (2006.5), but only slightly scarred the oem ****. About the only damage was stretching of the leather from the torque. It was a bit of a pain, but I'm liking the end results Installed the black aluminum Nismo shift **** in its place.
Old Jul 26, 2010 | 09:45 PM
  #122
bv0188's Avatar
bv0188
Man, I havent heard much about people trying this on an 07. Hope it comes off easy
Old Jul 29, 2010 | 06:20 PM
  #123
350zion's Avatar
350zion
Professional
I dont kno if anyone posted this but if the pole come loose heres what u can do I did mine a long time ago and didnt use anything at first to hold back so then the whole shaft started to spin. After breaking the oe loose with out destroying it I pulled the whole shaft out cause it was already loosening up. I decided to go further and cut mine down I forget how much i took off but use common sense u dont wanna go to low cause then the shift **** will be below the trim and i dont think that is cool .. but who am i .. any way after cutting it I used this stuff called GORILLA GLUE I bought at a local supplier but im sure the depot sells it. That stuff works wonders use a little and it expands something wicked. I promise u it will hold anything tight . Its been 4 years and 2 shift **** mods later and still holding up. So dont sweat it if the **** and the chrome shaft come loose jus gorilla glue that biatch back on n u will roc out. BTW this isnt to promote effing ur car up jus a quick fix if u do mess this up,,and it worked for me. good luck.. happy modding....
Old Apr 1, 2011 | 05:49 AM
  #124
NZMOWND's Avatar
NZMOWND
mine twisted off without even removing the ring around shift boot...i think since i bought mine used it had been done before and broken loose...thats what im hoping for!! thank god for an 08!!
Old Jun 14, 2011 | 09:15 AM
  #125
TPete19's Avatar
TPete19
replaced the shift **** on my 07. Unsnapped the shift bezel, held onto the lower part of the shifter with a pair of 10" channel-locks, then unscrewed the stock **** by hand. It was on there tight, but with the shaft held in place, the shift **** didn't require a tool to remove.
Old Jan 22, 2013 | 06:14 PM
  #126
SeriousbiZness's Avatar
SeriousbiZness
Default loose jdm
so i just installed my jdm **** i got as an xmas present but after screwing it on its still loos and the boot hangs down a few inches which i cant stand. the **** only came with a spacer thing that threaded on and the **** itself. any ideas on how to sort this out, anyone?
Old Apr 22, 2013 | 08:30 PM
  #127
Kody8800's Avatar
Kody8800
what is the size of the shaft on the 03 350z?
Old Jun 27, 2016 | 11:28 AM
  #128
Heritage's Avatar
Heritage
Here's what I don't understand ('03).
I disconnected the top trim, saw the cotton batting and the rubber boot below it - and that boot is secured to the transmission tunnel with 4 bolts - which I removed. That boot's sleeve extends upwards into the ring and zip ties which secure the leather shift surround. Once the 4 bolts were off, I lifted the boot (it was fused onto the tranny tunnel) a smaller rubber boot was revealed, which can be pushed somewhat down to expose the metal shifter shaft.
It is on that shaft that I locked a vise grip.
It then becomes obvious that there is a PLASTIC sleeve on the metal shaft above that point, over which the upper boot is slid, and - somehow - to which the **** is attached.
They both spin together - but the **** is not unscrewing from the shaft, as the '03 shop manual seems to suggest should be the case.
I then chose to grip to the plastic sleeve with another set of vice grips, and that stopped my ability to turn the **** dead in its tracks.
WTF? I must have rotated the entire assembly (****, surround, boot, plastic sleeve) 15 times, and gotten no where - even though the shifter shaft itself was not turning at all.
WTF am I missing? Is there a fitting within the **** itself which is screwed onto the shaft, and all I've done is (easily) strip that fitting from the surrounding shifter ****?
Pulling my hair out on this.
Old Jun 27, 2016 | 12:25 PM
  #129
Heritage's Avatar
Heritage
^I rewrote that for better clarity. I'm totally confused by this ****: it spins freely - the shaft isn't - but it will not come off.
Who knows what's going on?
Old Jun 27, 2016 | 01:32 PM
  #130
Heritage's Avatar
Heritage
It came off.
It looks as though the threaded part of the **** is a sleeve within the **** - and you have to PINCH the uppermost part of the thin base (on the leather of the ****) in order to properly transfer clamping force to this inner sleeve - which happens to be where the red loctite is applied.
Otherwise this inner sleeve simply spins inside the **** - and you'd have to destroy the **** to get to it to then remove it.
Annoying.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
