DIY: Painting '06- Headlights.
Old Apr 30, 2009 | 12:29 AM
  #141
gennosuke1's Avatar
gennosuke1
i was reading somne threads on here and it said that 03-05 dont have a true projector so when you painting the headlight you are kinda of covering or lessing the light that can be potrayed. is this the same with 06 Hid they have projectors but i mean will the light be less bright or not?
Old Apr 30, 2009 | 07:33 PM
  #142
gr8scott_o's Avatar
gr8scott_o
No. The '06-'08 lights reflectors are integrated into the "eye" of the headlight. Blacking out the headlight will not impact light output.
Blinkers are another story. Certainly diminished output, but can still be seen during the day. Going a gloss black will help somewhat.
Old Jun 26, 2009 | 03:55 PM
  #143
BigMo350z's Avatar
BigMo350z
Amazing write up!
Old Jul 2, 2009 | 04:58 PM
  #144
GordonBombay's Avatar
GordonBombay
This is by far one of the best DIY threads out there but I was wondering if this process would work with the 03' headlights as well. Would there be any diminished light in the 03' unlike the 06'? I have an 03' and I am looking to do it to match my Daytona Blue Z.
Old Jul 2, 2009 | 05:03 PM
  #145
omega6's Avatar
omega6
03's if u fully black them out, it WILL diminish the light out put
some people don't pain around the HID section on the '03s to maintain the output
Old Oct 1, 2009 | 03:33 PM
  #146
BigMo350z's Avatar
BigMo350z
Nice write up! It's time for a change!
Old Oct 2, 2009 | 11:18 AM
  #147
BigMo350z's Avatar
BigMo350z
Old Oct 16, 2009 | 10:50 AM
  #148
Jay'Z's Avatar
Jay'Z
Originally Posted by rgorajia
Here is the close up pic
I have that same problem...... I am currently pulling apart the headlights and going to try to swap an ebay set of headlight lenses for the ****ed up clear lenses...
Old Oct 16, 2009 | 06:51 PM
  #149
Jay'Z's Avatar
Jay'Z
Look at my lenses...... This wasnt done by me btw.. It was Mr. Zipps.....
Old Oct 16, 2009 | 10:43 PM
  #150
itsmeahb's Avatar
itsmeahb
looks good!
Old Oct 17, 2009 | 06:18 AM
  #151
tight350z's Avatar
tight350z
damn man.. mine are the same way though.. but mine happened bc i had mine overlayed with bats vynil...good news is the 03-05 lights have the same mounting points on the clear lens, so if you can find some of those in good shape you can just swap it out!
Old Oct 17, 2009 | 06:25 AM
  #152
Jay'Z's Avatar
Jay'Z
Awesome!! Thats the info I was looking for!! Im going to do that... I ordered the ebay lights and Ill pull the lenses off....
Old Oct 17, 2009 | 12:49 PM
  #153
bapestah's Avatar
bapestah
Wow awsome info in this write up, thank you all!
I'll be attempting this during the weekend but Im still unsure on some details.... Should I use a Cardboard box or a baking sheet? Whats the best way to prevent fogging?
Old Oct 17, 2009 | 01:17 PM
  #154
Mazinger Z's Avatar
Mazinger Z
Looks good guys!
Old Oct 18, 2009 | 04:44 PM
  #155
gr8scott_o's Avatar
gr8scott_o
Baking sheet is all that is needed. Do not do cardboard. Look at your oven before you turn it on and do a trial fit... make sure the rack, sheet and light are as far away from the heat element as possible, and no part of the light assembly touches the sides of your oven. Do LOW heat for LONGER periods of time, I did 250F and checked it at 12 minutes, loosened the cover as much as I could, then typically put it back in for 5 mins or so before taking it out again and finishing the job.
Helpful hints:
  • Get leather gloves... it will be uncomfortably hot.
  • Set it down on a towel that you don't mind throwing away
  • Use two people... one to hold on to the base and one to pull off the lens.
  • Pull the lens FORWARD, not UP. Really only possible with two ppl, unless you secure or bolt the housing to something first.
  • When the adhesive starts to give, it will get stringy and very sticky. Be prepared to deal with that. You will want to avoid getting that gooey stuff on anything you like, especially any part of the light.
I personally believe (but have no proof to back it up) that the stress cracks like the kind seen on Jay'Z lenses are because one person pulled the cover off themselves... they stood behind the light, put their hands on the front, and then pulled up and back. With only one person, that is the easiest way to do it. However, I think that could create stress on the lens that could show up later.
Good luck.
Old Oct 18, 2009 | 04:51 PM
  #156
bapestah's Avatar
bapestah
Helpful hints:
Good luck.
Great info, Thanks a lot!
Old Oct 18, 2009 | 04:52 PM
  #157
Jay'Z's Avatar
Jay'Z
Thanks great info gr8scott!!
Old Oct 18, 2009 | 06:32 PM
  #158
Jay'Z's Avatar
Jay'Z
Originally Posted by tight350z
my stress cracks actually formed from putting vynil on mine... they were like that before i even pulled them off the car..im not so sure about the pulling apart theory but anythings possible..
heres some shots of mine i did w/ the halo too..gloss black
Damn bro... Its pissed me off so much Im contemplating selling them as is......
Old Oct 18, 2009 | 06:50 PM
  #159
tight350z's Avatar
tight350z
just throw some lenses on them.. the paint looks great!i am split on the ebay lenses bc i have heard bad things about them as well..and then some ppl have had great luck.. eitherway, it might be worth a shot for u.. if not, id try to find some base 03's that are brandnew.. maybe dealer? you just want the OEM lens
Old Oct 18, 2009 | 07:06 PM
  #160
gr8scott_o's Avatar
gr8scott_o
.gloss black
Gawd, gloss black looks so good...
