headlight bulb questions
what bulb is my high beam and what bulb is my low beam ? when i got the car the headlights were mostly broken and riced out. i have an 05 enthusiast. one light has a small h7 ballast and an led. is that my low beam? and i do have the large black ballasts for the other light it looks to be xenon. that is in the spot for the projector. also how do i clip the lower light in? i cant seam to figure it out.
I think that might be the H7 which would be your high beam. Your low beam should be a D2R HID bulb. The LED is not OEM so I don't have a clue how to resolve your problem. I suspect a standard H7 halogen would fit correctly but I don't know if the original owner messed with your wiring since the halogen would not require a ballast. I hope this makes sense.
Unfortunately I don't know of any bright LED kits. You might be better off returning to the stock configuration of H-1 HID and H-7 halogen. Once you have everything working correctly, then think about making changes.
Diode Dynamics
Body Interior
May 27, 2021 11:07 AM
0taku
Jul 22, 2017 04:07 PM
