DIY - SPL Compression Rod Bushing Install
Old Aug 11, 2015 | 07:06 PM
  #81
adamgfn's Avatar
adamgfn
Quick, I need help getting the compression rod back on. I tried jacking up the translink but no luck. wtf do I do?
Old Apr 11, 2016 | 01:03 PM
  #82
Bak3rme's Avatar
Bak3rme
i got the bolts for the ball joint and the brace off to remove the compression rod. how the heck do you get the compression rod off once all bolts are removed
Old Apr 11, 2016 | 05:59 PM
  #83
Rev_Night's Avatar
Rev_Night
as the first page of instructions say, use a prybar to force the compression rod down. The lever point is right at the bushing (more inner of car), not the ball joint (more towards the wheel). Using a prybar sounds like hard work, but it fell down very easily for me.
Old Apr 16, 2016 | 02:46 PM
  #84
RobPhoboS's Avatar
RobPhoboS
I had a weird one with this today, did the passenger side first, no problem.
Pressed out the driver side bushing (I had SuperPro in there), then went to press the spl in place... If just fell through the hole!
I measured the spl, it's roughly 60.4mm, so I believe it's fine and that somehow the compression rod has distorted, strange.
Anyone else had that?
Old Apr 16, 2016 | 02:51 PM
  #85
Rev_Night's Avatar
Rev_Night
Nah man it worked just fine for me
Old Apr 18, 2016 | 02:00 AM
  #86
RobPhoboS's Avatar
RobPhoboS
Good:
Bad (very)
New arm on the way, and no, I didn't drive around on it.
EDIT:
New arm worked, so pressed in as usual
Old Jun 12, 2016 | 12:14 PM
  #87
rizeld's Avatar
rizeld
I did similar, except I bought brand new rods from amazon and pressed out the new rubber ones and replaced. Did the work in Hobby shop (military)
Attached Thumbnails DIY - SPL Compression Rod Bushing Install-20160611_130713_resized.jpg   DIY - SPL Compression Rod Bushing Install-20160611_130814_resized.jpg   DIY - SPL Compression Rod Bushing Install-20160611_131535_resized.jpg   DIY - SPL Compression Rod Bushing Install-20160611_131905_resized.jpg
Old Jun 14, 2016 | 01:03 PM
  #88
rustyschopshop's Avatar
rustyschopshop
I used to use SPROCKET on fort hood. Really nice facilities.
Old Jun 22, 2016 | 11:35 AM
  #89
rizeld's Avatar
rizeld
Nice, Ive noticed it definitely matters what installation you're on and what the AD population is. Ft Detrick is probably the tiniest base Ive been on with the smallest Hobby shop, vs APG which use to be an AIT training location and its Hobby shop was well put together and very clean
Old Aug 31, 2016 | 01:33 PM
  #90
mcrk.button's Avatar
mcrk.button
http://www.ebay.com/itm/291850799215?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
anyone use these before?
Old Sep 13, 2016 | 06:36 AM
  #91
Headsick's Avatar
Headsick
Thanks for the write-up. FYI, if anyone is having trouble finding the recommended DOM steel tubing, you can get it online. http://www.onlinemetals.com/
Old Jan 9, 2017 | 10:28 AM
  #92
amr_electron's Avatar
amr_electron
Oh boy, The passenger side was a b!.ch !!!, I soaked it in WD-40 for days before doing the install but it was rusted & fused to the bolt.
Had to use a chisel, pry bar, pipe wrench, hammer, gear puller ... to get it out ...
Old Apr 14, 2017 | 05:06 AM
  #93
trusovici's Avatar
trusovici
Default bushing removal with autozone loaner tool
Hey i just did my whole front end with the whiteline essentials kit. I found that the autozone master ball joint press kit ( part # 27310 )comes with a receiving tube that works perfect to press out the old bushing. It has a stepped end which also aids in centering. Popped them right out using my harbor freight 12 ton press.
Old Feb 15, 2019 | 09:02 AM
  #94
Rey Aguilar's Avatar
Rey Aguilar
Default Compression rod
Hope you see this, but what compression rods did you buy off amazon? I heard some aftermarkets don’t work with spl bushings?
