How-to: Change Brake Pads
Old Nov 8, 2007 | 11:59 AM
  #201
JasonZ-YA's Avatar
JasonZ-YA
now thats a sweet too.......ive never seen that caliper spreader too....im gonna go get that..
Old Nov 9, 2007 | 10:55 AM
  #202
conecrazy's Avatar
conecrazy
you know you can use a flat head screw driver instead of the press tool also. it's faster too. basically with the caliper down, take out the outer pad and pry back the piston with the flat head between the rotor and inner pad. it's ok it doesn't damage the rotor cause you're only using the edge of it as a fulcrum to push the old pad back.
you might need to reinsert the old outerpad if you can't push the piston back far enough. i learned this from a dude that used to work at SGP.
Old Nov 18, 2007 | 11:04 AM
  #203
DVFlyer's Avatar
DVFlyer
Speed of White
Replaced my pads and rotors using this DIY. Took me two hours total (could have done it in one, but with two toddlers roaming, there was always a distraction of one sort or another). The only snag I ran into was the right side rotor did not want to come off. It was rusted on the hub. I used some Lime Away and a couple more whacks with the hammer and it popped off.
Many thanks.
Old Nov 19, 2007 | 11:53 AM
  #204
runz's Avatar
runz
This thread is freaking awesome! Def helped me out alot. Thanks!
Old Nov 20, 2007 | 10:23 AM
  #205
03zcarfl's Avatar
03zcarfl
bout to go try this now.. thanks for the info
Old Nov 21, 2007 | 04:46 PM
  #206
Mr_Kebo's Avatar
Mr_Kebo
Very Good write up. Pictures are worth a thousand words..
Old Nov 29, 2007 | 09:30 AM
  #207
WhiteNoiz's Avatar
WhiteNoiz
I too will be using this write up, thanks all!
Old Jan 4, 2008 | 08:00 PM
  #208
TARGET350Z's Avatar
TARGET350Z
Great write up!!
Old Feb 18, 2008 | 05:28 AM
  #209
DouBLeJ16's Avatar
DouBLeJ16
I just did mine over the weekend, front and rear in about 2 hours.. First time I've ever done brakes on a car.
It went extremely smooth. Pads feel great, and no more squeaking
Thanks for the write up!
Old Mar 15, 2008 | 01:58 PM
  #210
rfdgn1228's Avatar
rfdgn1228
great directions!! just did my front brakes this morning.
a lot easier than i expected.
Old Mar 17, 2008 | 07:53 PM
  #211
pearlwhite_z's Avatar
pearlwhite_z
I will be doing my hps pads this week on my 03 enthusiast ...first time so hopefully things will go smooth
Old Mar 30, 2008 | 04:36 PM
  #212
lbz's Avatar
lbz
I looked at my rear pads today, compared to the new Hawks I bought, they have about 50% of the material remaining. This at just under 48k. Is this unusual? I replaced the fronts at 30K with Hawk HPS.
Old Mar 30, 2008 | 10:06 PM
  #213
PrevWon's Avatar
PrevWon
Nice. Thanks for the instruction!
Old Apr 18, 2008 | 06:57 PM
  #214
Blazemaster's Avatar
Blazemaster
I just tried doing this myself and can't figure out how you guys were able to compress the pistons at all? My brake pads were really worn and the pistons were so far pushed out that it cannot cover over the new thicker pads. When you guys said that you have to drain out some of the excess brake fluid from under the hood, I looked in the brake fluid section, is the reservoir the smaller round one? I drained out all the fluid I can get out of there, but it didn't help with the piston compression. Any help?
Old Apr 19, 2008 | 01:09 AM
  #215
j3dz's Avatar
j3dz
I'm no expert, but I think the small round one is the Clutch fluid, and for the piston compression....nothing a C clamp can't handle. Good Luck man!
Old Apr 19, 2008 | 01:17 PM
  #216
Blazemaster
why would the clutch fluid be connected to the brake caliper? makes no sense...
Old Apr 30, 2008 | 05:12 AM
  #217
ReelBigAndy's Avatar
ReelBigAndy
It isnt, I think he meant this:
"I'm no expert, but I think the small round one is the Clutch fluid.
And for the piston compression: nothing a C clamp can't handle. Good Luck man!"
I'm sure you've done this by now, but make sure you replace any fluids you've drained out.
Old Apr 30, 2008 | 08:43 AM
  #218
j3dz's Avatar
j3dz
wat?.....I'm saying you drained your clutch fluid not your brake fluid....the clutch fluid is in the small round one and the brake fluid is in the larger rectangular container.
Old Jun 6, 2008 | 07:45 AM
  #219
ke0ki2k's Avatar
ke0ki2k
great instructions. bout to go install this P-Mu HC+ pads....bed em in and see how they perform up at the dragon ^_^ might try RS-4's after that
im surprised just how easy the install was....the non-brembos are super easy to work on.
Old Jun 14, 2008 | 12:46 PM
  #220
calprl's Avatar
calprl
thanks for the write up and pics...just installed a set of Hawk Pads on the front and rear. This made it really easy!!!!!!!!
