RS-R Ti-2000 G35 coupe springs
Old Dec 15, 2004 | 09:38 PM
ZZtopp's Avatar
ZZtopp
Default RS-R Ti-2000 G35 coupe springs
Has anyone tried these on the Z?
Old Dec 16, 2004 | 11:27 AM
kzshin's Avatar
kzshin
I have RS-R Ti 2000 FOR Z on the Z. if this is what you are asking.
Old Dec 17, 2004 | 12:20 AM
ZZtopp's Avatar
ZZtopp
Actually, I was interested in the drop (and the ride/handling) the G35 coupe springs would give the Z.
Old Dec 17, 2004 | 06:54 AM
350ZOWNZ's Avatar
350ZOWNZ
The ride quality might be better (softer springs) but the handeling would be worse.... They also lower probably less for the 350Z. I beleive the 350Z is already half inch lower than the G35Coupe...
Old Dec 17, 2004 | 11:39 AM
kzshin's Avatar
kzshin
might not lowered at all. Cuz if I remeber correctly, if you put 350Z's stock spring to G35C it will lowered the G35C.
Honestly, you should just get RS-R spring that's designed for Z, it only drop 0.6 inches, not that much. I have been driving in city of LA and no problem.
Old Dec 17, 2004 | 02:07 PM
ZZtopp's Avatar
ZZtopp
Thanks. How does the ride and handling compare to stock?
Old Dec 17, 2004 | 02:14 PM
bwzabodyn's Avatar
bwzabodyn
Spring rates are screwed up for almost ALL springs offered for the G - that's why I've been looking towards purchasing the RS*R springs designed for the Z... all the G spring rates are stiffer in the front than in the rear, which ultimately increases understeer in an already understeer-prone vehicle...
Personally, I'd stick with the H-techs you have if you're worried about ride quality...
Old Dec 19, 2004 | 01:41 AM
kzshin's Avatar
kzshin
Ride is not that much different from stock, if there is, it's very minimum. Handling wise, the body roll is less, but if you want to notice big difference, coilover system is what you want. Unless, you get the springs and shocks together.
Jambo016
Sep 16, 2016 01:08 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
