Why I don't like drilled rotors
Old Feb 4, 2005 | 12:59 PM
EnthuZ's Avatar
EnthuZ
Default Why I don't like drilled rotors
While (finally) cleaning my Z a couple days ago, I noticed radial cracks on each of my rear aftermarket Track rotors. Each rotor had only one similar crack per side. The rotors had been subjected to about 10 track days.
Not sure when it happened, but I bleed my brakes before EVERY track event, and this is the 1st time I noticed them.
New slotted only 2 piece replacements have been ordered.
I knew there was a reason I chose my slotted front BBK.
So kids, make your choice wisely.
D*mn.....can't get the pix to attach!!!
Old Feb 4, 2005 | 01:05 PM
John's Avatar
John
Yep, drilled rotors are the suck. Quite prone to cracking since the drilling process weakens the integrity of the cast.
Old Feb 4, 2005 | 01:10 PM
J Ritt's Avatar
J Ritt
Don't even get me started on the drilled....
Old Feb 4, 2005 | 05:01 PM
King Tut's Avatar
King Tut
Default Re: Why I don't like drilled rotors
What aftermarket rotors are they? I would think that that would be expected after 10 track days. How many track days should a set of rotors last?
Old Feb 4, 2005 | 09:48 PM
isugoo's Avatar
isugoo
so... you don't recommend drilled rotors for z?
you guys sold alot of drilled bbk for the z but actually not good?
hmmm. i liked drilled look more than slotted..
Old Feb 4, 2005 | 09:57 PM
EnthuZ's Avatar
EnthuZ
Default Re: Re: Why I don't like drilled rotors
DBA. I think they were the 1st high performance rotors available. Well, they did last 9 track days!
Old Feb 5, 2005 | 07:19 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Marketing aside, I've never found a practical difference between a slotted and drilled. I find its far more important to get a pad that will behave with the specific metal compound of the rotor...this, and proper ductiong, promotes goo pad and rotor life. Lots of vey badass cars use drilled rotors from the factory (I am talking money no object cars). Surely they had slotted or solid rotors at their disposal (these are cars costing 75k and up). Not saying there is a specific reason they went to a drilled rotor, but poo-pooing the idea off the bat cannot be a very good way to look at things. FWIW, I have had drilled rotors on several of my own track only cars...the small hairline cracks are normal and tend to go away after a rotor is cut.
Now, what I will grant you, is like everything in life, there are good and bad manufacturing processes...this is what tends to seperate products such as this in my experience.
Old Feb 5, 2005 | 01:47 PM
SirZaLot's Avatar
SirZaLot
But DBA should be a pretty good name, no?
Old Feb 5, 2005 | 03:24 PM
Z1 Performance
Former Sponsor
never used them so I cannot say
Old Feb 8, 2005 | 10:13 AM
OvaYahead's Avatar
OvaYahead
Has anyone tried out these EBC rotors? I was thinking about trying them out. Their dimpled not drilled.
http://www.ebcbrakes.com/Automotive.html
Old Feb 14, 2005 | 07:16 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
