Hawks HPS brake noise
Old Apr 9, 2005 | 07:51 PM
JoneZZZ's Avatar
JoneZZZ
Hmmm.....lightly toasted I take it.... ......sounds like you got part way through the bedding process....check out the following:
http://www.zeckhausen.com/bedding_in_brakes.htm
"A bad smell from the brakes, and even some smoke, is normal....."
Old Apr 10, 2005 | 06:54 AM
VinUnleaded's Avatar
VinUnleaded
The noise problem seems to have cured itself..
Not 100% noiseless, which Hawks even admits but 99% noise free.
I am not sure if somehow I embedded them, or maybe the dealership did and it just took awhile for the pads to wear the coating off.
Regardless, almost noiseless now.
Old Apr 10, 2005 | 07:14 PM
JoneZZZ's Avatar
JoneZZZ
VinUnleaded....glad the noise problem is cured! I really like the Hawks pad, I have noticed a significant reduction in brake dust with them...and no noise.
As far as the bedding process and "smoke"....I took mine out to a deserted road and did 8-10 hard stops.....and there was no question about the smoke!
A guy passed me going in the opposite direction as I was doing one of my last runs.....his eyes about popped out of his head looking at the smoke coming out of all 4 wheel wells
My brakes are perfect now!!!!
jasoni1.......go ahead and "burn 'em in" good!
Old Apr 10, 2005 | 10:01 PM
ssk0771's Avatar
ssk0771
Originally Posted by VinUnleaded
I bought these brakes because my stock brakes had 19k on them and were "beginning" to squeal.
I purchased Hawk HPS based on many recommendations and accolades and had my dealership install them while gettting my Oil Change Service etc.
Guess what?
They squeal!
What gives?
The box even says quiet.
They are not....
I was told this is due to the fact my dealership didnt turn the rotors.
First time ever I havent had rotors turned too...usually a dealership insists on turning them.
Now what? The Nissan dealership says they arent covered under warranty because I supplied them.
A local Z shop told me 2 new pairs, have them reinstalled on turned rotors, and "embedded".
I dont feel like spending all that money over again...guess I will just live with the noise.
I had Hawk HPS Brake Pads both front & rear up until yesterday and I never had a squeel.
Here is few things my mechanic did when installing the Hawk pads.
First, he turned the rotors so they are smooth.
Very Important: second, he did not put the metal shim that goes between the caliper and the brake pads. He said that Hawk pads already come with metal shim on the back of the pads so there is no need for it and he also said that if I want to put the metal shim on he would put it on but it may cause squeel.
Old Apr 10, 2005 | 10:10 PM
xxlbeerZ's Avatar
xxlbeerZ
Mine squeal sometimes (based on weather conditions it seems), but I ****ing hate brake dust. So it's an ok trade off.
Old Apr 11, 2005 | 04:47 PM
LaidbackRacr's Avatar
LaidbackRacr
Anyone considered the rotors might be glazed? I had the same problem with my HAWK pads and turned the rotors and valla no more noise
Old Apr 12, 2005 | 06:14 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
I just installed the HAWK pads on my stoptech 14 inch kit, and they are much quiter than my old pads. If mine squeak or squeal at all, i have yet to hear it. Most high performance brake setups, regardless of pad, will squeal some, but these pads on my application have helped a great deal.
Old Apr 12, 2005 | 06:31 AM
rednezz's Avatar
rednezz
Guess what?
They squeal!
What gives?
They are not....
You just need to grease the shims.
Old Apr 20, 2005 | 12:26 PM
Zquicksilver's Avatar
Zquicksilver
Good info... getting my HPS pads installed tonight at PepBoys Now to find a place where I don't make a J.A. out of myself when braking them in...crap...I live in downtown Chicago!!!
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
