Tokico vs Koni Shocks??
Old Apr 17, 2005 | 07:18 AM
zzzya's Avatar
zzzya
Default Tokico vs Koni Shocks??
I have been searching a few sites looking for some good reviews of these shocks but have not found much. There was a lot of discussion back before either of these came out and around the time they hit the market, but it doesn't seem like many people posted reviews, or the search function isn't hitting on them for some reason.
I am looking for a shock to complement the RSR Ti2000 springs that I have had for a while. From what little info I have seen, either shock will be much better than the stock ones. I am curious as to whether or not the extra money for the Koni shocks is actually worth it or not. Any opinions?
Old Apr 17, 2005 | 07:28 AM
2003z's Avatar
2003z
I have the tokico's and love them with eibach springs. Sure, the koni's are a little easier to adjust the rears, but I don't change them every day. Once you get them where you like them, you leave them.
Old Apr 17, 2005 | 02:51 PM
zzzya's Avatar
zzzya
Did they eliminate the highway bounce of the stock shocks? What other comments do you have about them and their overall handling performance?
Old Apr 17, 2005 | 05:01 PM
2003z's Avatar
2003z
Our roads are pretty good here in Ga. I never really experienced the bounce, but the ride is definitely smoother. When you hit a bump though, the ride is nicely damped, even on soft settings. (I have them at 5 out of 7 for softness since my wife and I drove to orlando a couple months ago. Handling performance is great, they are something I would definitely do again.
Old Apr 18, 2005 | 03:35 PM
zzzya's Avatar
zzzya
Anyone with Koni shocks that could help with this decision?
Old Apr 18, 2005 | 06:06 PM
benzz280's Avatar
benzz280
I once read that the rear tokicos' dials can be accessed easily if u drilled a small hole on the rear strut bar, but dont know where exactly, any1 who knows care to elaborate?
Old Apr 18, 2005 | 08:06 PM
Autobahn's Avatar
Autobahn
I have the Koni's on my 2003 Touring. Previously I was suffering very badly from highway bounce. I added Koni's plus Tein-H srings and the ride is notably improved. Can hardly detect the freeway bounce. Highly recommend the Koni's. Expensive but worth it. I also added the Hotchkis Sways. That probably was the biggest bang-for-the-buck improvement I did to the car.
Old Apr 19, 2005 | 02:32 AM
jmark's Avatar
jmark
Konis + stock springs + 350Evo sway bars = both ride and handling improvement
Old Apr 24, 2005 | 03:11 PM
myGspot's Avatar
myGspot
dont forget one thing.... KONI offers lift time garantee on the shocks. I"m not sure if Tokico does the same.
Reason why i broght it up is I had koni;s on my Honda Prelude. For some reason after one really cold winter, they leaked a bit at the top at the adjusting point. So i called KOni and they sent me new shocks. No fuss nothing.
Old Apr 24, 2005 | 06:20 PM
2003z's Avatar
2003z
Since, at the 2.5 year point, I have now owned the Z longer than 27 of the last 29 cars I have purchased, a lifetime warranty is of little concern to me
Old Apr 26, 2005 | 03:33 AM
zzzya's Avatar
zzzya
Both have very similar Warranty statements, basically lifetime with certain limitations as usual.
Old Apr 26, 2005 | 08:55 AM
LaidbackRacr's Avatar
LaidbackRacr
Not had Koni on my Z but in my last 2seater sports car they were too bouncy for me. I like KYB myself
Old Apr 26, 2005 | 09:11 AM
zzzya's Avatar
zzzya
Just how hard are the rears to adjust for either set of shocks. It is sounding like they will both work out in every aspect, but one thing I will do quite a few times during the year is visit the local 1/4 mile track and it would be nice to be able to adjust the rear shocks to a softer setting while out there to help shift weight to the rear tires for better launches. If one is really that much easier to adjust in the rear, then that may be the decision maker. If both require removal of the rear tires for rear adjustment, then I would consider that nearly equal for practical purposes.
Old Apr 26, 2005 | 09:29 AM
del105's Avatar
del105
15 f125
I'm a huge fan of Konis The konis are absolutlely easier to adjust. The tokicos need to be unbolted at the top to adjust, the konis do not. Also it is very easy to get the konis revalved. To be fair the only tokicos I've owned are the stock shocks which are made by tokico, they are not very good.
Old Apr 26, 2005 | 01:31 PM
zzzya's Avatar
zzzya
Thanks for the input guys. I decided to go with the Konis mainly because of the ease in adjustability on the rears. I may never end up using that feature much, but it is nice to know I will have it. That plus I went with the 350EVO a-arms and they have a good price on the Konis so I was able to buy from one of my favorite vendors and decrease shipping costs. All in all I am sure I will be very pleased. I will post impressions after install and realignment.
Old Apr 26, 2005 | 04:35 PM
2003z's Avatar
2003z
just so you know, you don't have to take the rear tires off to adjust the tokico's either. Just jack the rear up. You do have to remove the 2 12mm upper mounting bolts, but it takes less than an extra 5 minutes over the konis.
Old May 17, 2005 | 01:01 PM
VR3's Avatar
VR3
How are the Konis working out?
Old May 17, 2005 | 01:55 PM
zzzya's Avatar
zzzya
Well, I installed them last weekend and unfortunately I have not had a chance to drive the car since the install because it has been in the shop waiting for some backordered part to come in and get a 4 wheel alignment. I have yet to play with the settings, make any adjustments or do any sort of spirited driving.
Old May 18, 2005 | 07:05 AM
VR3's Avatar
VR3
Looking forward to your review. Are you getting the alignment because of the a-arms you installed? I thought an alignment wasn't needed when shocks where installed because there is no height being adjusted with just shocks as opposed to installing lowering springs.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Nihsnek
Feb 9, 2016 12:57 AM
Paul.
Oct 16, 2015 07:34 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Suffolk350z
Sep 13, 2015 02:43 PM
